HK Talk Version 1.1
Old 11-14-2001, 01:53 AM
  #2146
Regional Moderator
disaster999's Avatar
Default Re: DTM, which car is better?
Originally posted by Stanley
PLs tell me which car is better ................pro 3, KX-1 and yokomo Sp, Thx!
yokomo all the waay...hahahah!!
disaster999 is online now
Old 11-14-2001, 02:08 AM
  #2147
ernestf: you should know which one is better.... or soon you will..
ME-student is offline
Old 11-14-2001, 02:34 AM
  #2148
ernestf's Avatar
Stanley, I have both KX1 and Pro3 but dont have the MR4TC Sp. But since I havent built the Pro3 yet, I should not comment its performance (Fai might help you tho, his Pro3 is FAST). But the latest Pro3 LE version (available in HK only, I think) do come with a lots of hopups parts and is good for the value in my opinion. You can refer to Fai's previous post on the items that come with the LE version.
I run stock motor on my KX1, and find that its still have to be further hopuped, ie, alloy motor mount, alloy spur adaptor. Also, I found Kyosho EP plastic material is not too durable, plays are now everywhere, especially in the front steering blocks ..... Also the front bumper (both plastic and foam) cannot "protect" the whole front part nicely, I killed a few front alloy t-bar (to cross the front a-arms) already.
On the other hand, its drive-train is very smooth and efficient. The car has a lot of rear traction and I am thinking a way to reduce this in order to achieve faster corners.
Hope this help.
ernestf is offline
Old 11-14-2001, 02:35 AM
  #2149
Regional Moderator
Originally posted by White cat
Shaft driven car is noisy. Can't help.
yupyup....same goes to TC3..its really noisey
Old 11-14-2001, 02:36 AM
  #2150
ernestf's Avatar
Talking
White Cat, my TC3 isnot noisy !!! But it is too efficient on its drive-train that the motor draw too much current from ESC and batt to heat up everything.
ernestf is offline
Old 11-14-2001, 02:54 AM
  #2151
ernestf: i also have this problem with my Kx-one.. the car has so much rear traction.. no matter what i do to it... it doesnt want to rotate about its z-axis... i am thinking about changing the batteries position. i saw on one japanese web a guy used saddle pack in the car. 3 on each side. i might do that.
Old 11-14-2001, 05:19 AM
  #2152
Regional Moderator
Originally posted by Tsubasa Sakai
Disaster999: Have any extra servos want to sell??That is what I am finding.
hehehe...nonno....i found some use for my 3 extra servo now....2 goes into the gp...1 goes in the ep...haha!!
Old 11-14-2001, 05:36 AM
  #2153
Manticore's Avatar
you've got a reason to dump your TC3 !!!!
Manticore is offline
Old 11-14-2001, 05:39 AM
  #2154
dtm
dtm's Avatar
Thats because your 'tub' won't let your batteries cool down!!!!! hehe....
dtm is offline
Old 11-14-2001, 05:53 AM
  #2155
Manticore's Avatar
well, ernestf's TC3 main chassis is one of the best modified chassis.
Old 11-14-2001, 05:55 AM
  #2156
Regional Moderator
really....batt doesnt cool down as fast as graphite?
Old 11-14-2001, 06:09 AM
  #2157
Manticore's Avatar
either woven graphite or graphite impeginated tub are bad conductor of heat. it is the problem with tub chassis as air flow is bad with the stand up "edge"
Old 11-14-2001, 07:34 AM
  #2158
Regional Moderator
anyone have problem setting the cyclone tc with 3PJ? i couldnt get the ESC to find nuetral and it has no brakes!
Old 11-14-2001, 07:37 AM
  #2159
Manticore's Avatar
you should restore all your setting about throttle on your TX first and redo radio calibration with the ESC. you might like to go back to one of the three default setting on the esc to avoid the 4th hidden setting from error setup if you have got the ESC from someone.
Old 11-14-2001, 08:07 AM
  #2160
dtm
dtm's Avatar
How many extra holes has he drilled in it???!
dtm is offline
