HK Talk Version 1.1
Old 11-12-2001, 09:25 PM
  #2056
Manticore's Avatar
Originally posted by Diva
But you could replace the broken gears. BTW, I have no single problem with it on my EP.
who wants to replace servo gear? if you buy a couple of set of plastic servo gear, you better go to a metal gear servo.
Manticore is offline
Old 11-12-2001, 09:26 PM
  #2057
Manticore's Avatar
Originally posted by fai
Ernest: A HK limited edition Pro3 is waiting for you!! Hehe...
as far as i know the TC3 Pro driver has bought the HK LE Pro3 !!
  #2058
Diva's Avatar
Trader Rating: 14 (100%+)
Originally posted by Disaster999
yupyup...after screwing and backing out the screws....the nylon started to wear out and the servo horn would just pop out...when that happens...the groves on the gears would then wear out and have absolutly no grip over the servo horn...
How frequent do you put on and take off your horn? Frankly, I seldom do that. Even if your gears went worn, there are replacement parts out there. You can't expect everything went perfect without wearing in R/C. To me, I've tried 9402, 2000, 2015, 2143, 2144, etc., 2015 is always my pick for EP.
Diva is offline
Old 11-12-2001, 09:29 PM
  #2059
Diva's Avatar
Nobody wants to replace servo gear. That's only a solution to the problem IF it occurs. To me, I don't have spare servo gear and I have NEVER broken any gear. That's why I like it.
Diva is offline
Old 11-12-2001, 09:37 PM
  #2060
Manticore's Avatar
touch wood !
Old 11-12-2001, 09:44 PM
  #2061
Diva's Avatar
Does anybody has the Japanese version of 9402?
Diva is offline
Old 11-12-2001, 10:07 PM
  #2062
fai
Regional Moderator
fai's Avatar
Diva: Mine is clearly not made in Japan, maybe made in China...
fai is offline
Old 11-12-2001, 10:23 PM
  #2063
ernestf's Avatar
fai, so what kind of hopups u have on your pro3 besides the upper deck ??? the HK LE edition is cool, but still missing alloy wheel hex and spur adapter.
ernestf is offline
Old 11-12-2001, 10:24 PM
  #2064
Manticore's Avatar
what what? no spur adaptor too???
Old 11-12-2001, 10:32 PM
  #2065
ernestf's Avatar
it surely come with spur adapter, but only plastic, not alloy
ernestf is offline
Old 11-12-2001, 11:03 PM
  #2066
fai
Regional Moderator
fai's Avatar
Ernest: I think you can have the aluminium spur gear adaptor... I got the one made by ToBee a long time ago, which is different from the one made by HPI. It's just a adaptor, without aluminium gear.
For the hex hubs, in the past, I used those Atlas one, so I think you can make use of them instead of getting HPI's...
I also got the front aluminium diff. holder (the two discrete metal blocks) but I don't think they are essential parts...
I think you can then keep your pro3 under $2000...
fai is offline
  #2067
dtm
dtm's Avatar
yes it works fine but you have a hidden worry there the plastic gear could be easily broken up !
I managed to break the plastic gears on my 2015 once. Made the mistake of installing the high torque servo saver from Kawada on the SV10.... it was so high torque that it didn't do much servo saving! Fortunatley plastic gears are cheap!!
I also stripped the one and only plastic gear in my metal geared 9402 before!
dtm is offline
Old 11-12-2001, 11:10 PM
  #2068
dtm
dtm's Avatar
Thats when you go from a 2.6mm screw to a 3mm screw for Futabas, or a 12mm length screw to a 15mm length screw for KOs. So far no real complaints for EP. I find that the metal gears in my 9402 has quite a lot of backlash also.........
And don't forget most metal gear servos have one plastic gear in the system as a weak link!!! So if it breaks....it breaks.... regardless of metal or plastic!
dtm is offline
Old 11-12-2001, 11:13 PM
  #2069
dtm
dtm's Avatar
I think mine is made in Taiwan!!!?!!
dtm is offline
Old 11-12-2001, 11:16 PM
  #2070
dtm
dtm's Avatar
hahaha...okok....
0.05sec?! holy sheet....what are they trying to do? kill the car?
No the servo is so quick it moves before you move your fingers!!
dtm is offline
