HK Talk Version 1.1
Old 11-12-2001, 09:33 AM
  #2041
Regional Moderator
disaster999's Avatar
anyone know what other fet servo does ko make? i got a second hand one...but the sticker is peeled off...and i have no idea what it is...its plastic gear!
disaster999 is offline
Old 11-12-2001, 09:57 AM
  #2042
dtm
dtm's Avatar
Originally posted by Disaster999
DTM: but the servo has the same speed as the futaba 9402...hahah..im have 3 extra servos lying around...and i have no idea why im getting more...hahahah!!
Because you are a collector of servos!!!
dtm is offline
Old 11-12-2001, 09:59 AM
  #2043
dtm
dtm's Avatar
If your lucky it will be a 2015..... one of the fastest servo made by KO 0.05s..... not too accurate but damn fast!!
dtm is offline
Old 11-12-2001, 10:00 AM
  #2044
dtm
dtm's Avatar
You can buy a KO spare case and it has ALL the stickers with it........ you can have whatever you want then!!!!!
dtm is offline
Old 11-12-2001, 07:51 PM
  #2045
Regional Moderator
hahaha...okok....
0.05sec?! holy sheet....what are they trying to do? kill the car?
Old 11-12-2001, 07:56 PM
  #2046
Manticore's Avatar
hahaha...okok....
kill the plastic gears !!
this is typical KO. make something that will destroy itself!
Manticore is offline
  #2047
Regional Moderator
hahah...i want to be...but with only 3 servos...how could i be a collector?
Old 11-12-2001, 08:07 PM
  #2048
Regional Moderator
haha...may be im not so lucky after all....hahha...my servo isnt that fast...even with the fet installed....the servo twitches when i had that fet on so i soldered the line to the power line on the servo...that made the servo more stable but with out lacking speed. the servo with 6v has about the same speed as the s9402. i want to switch it to metal gears tho...
Old 11-12-2001, 08:16 PM
  #2049
Diva's Avatar
Trader Rating: 14 (100%+)
Plastic gear is much lighter. And I'm installing it on my EP one year ago and it's still going fine. One of the best servos of KO
Diva is offline
Old 11-12-2001, 08:20 PM
  #2050
Manticore's Avatar
yes it works fine but you have a hidden worry there the plastic gear could be easily broken up !
Old 11-12-2001, 08:24 PM
  #2051
Regional Moderator
yupyup...after screwing and backing out the screws....the nylon started to wear out and the servo horn would just pop out...when that happens...the groves on the gears would then wear out and have absolutly no grip over the servo horn...
Old 11-12-2001, 09:05 PM
  #2052
Manticore's Avatar
yup yup
Old 11-12-2001, 09:20 PM
  #2053
Diva's Avatar
But you could replace the broken gears. BTW, I have no single problem with it on my EP.
Diva is offline
Old 11-12-2001, 09:22 PM
  #2054
fai
Regional Moderator
fai's Avatar
Wow, 2015 is really a fast servo, I used it for some time in my EP and finally it became a little noisy... maybe the noise came from the plastic gears... I swap back using my Futaba long-life 9402...
fai is offline
Old 11-12-2001, 09:24 PM
  #2055
fai
Regional Moderator
fai's Avatar
Ernest: A HK limited edition Pro3 is waiting for you!! Hehe...
fai is offline
