HK Talk Version 1.1
Old 11-04-2001, 10:10 AM
  #1696
ernestf's Avatar
dtm, which corally motor (11x2 ?) you are using ? where can i buy it ?
ernestf is offline
Old 11-04-2001, 10:12 AM
  #1697
Manticore's Avatar
JetHobby
Manticore is offline
Old 11-04-2001, 06:59 PM
  #1698
Mars's Avatar
Originally posted by Jean Alesi
Mars: what tires Alan Yau is using??
in the A mains, he used 139GS.
Mars is offline
Old 11-04-2001, 11:02 PM
  #1699
fai
Regional Moderator
fai's Avatar
Mars: I see... may be next time I can race with you so that I can test the tires for you during the qualifies!!!
fai is offline
Old 11-04-2001, 11:04 PM
  #1700
fai
Regional Moderator
fai's Avatar
Dtm: Oh, you get the stock motor from Fat Lee Lom then!? So, next time when we met at PYC, can you kindly carry me back to HK side? I lived in Western District by the way...
fai is offline
Old 11-04-2001, 11:08 PM
  #1701
fai
Regional Moderator
fai's Avatar
Wow, congratulation to Masami, dominated the JMRCA 1/10 EP...
fai is offline
Old 11-04-2001, 11:55 PM
  #1702
dtm
dtm's Avatar
Originally posted by Manticore
is Ying Gor and Jong sau lo going to switch to xray?
My computer 'hung' after my last post last night... so I gave up!
We are working on getting them onto Xrays.... it's just a matter of time!
dtm is offline
Old 11-04-2001, 11:57 PM
  #1703
dtm
dtm's Avatar
JetHobby
If only they had any stock!!! We have had to specially pre-order some armatures! don't know when they will be arriving!!
Ernestf- I like the 11x2 Gold best at PYC!
dtm is offline
Old 11-05-2001, 12:01 AM
  #1704
dtm
dtm's Avatar
You should have mentioned it last Friday!!... should be no problems. We normally stop off at Tai Po for a 'midnight snack' and a 'debrief' for the night! so normally get back fairly late/early..... 3-4AM... but if you don't mind?!
Found out that my car had its picture taken a couple of weeks back for speeding!!!!! Those Police never sleep!!!
dtm is offline
Old 11-05-2001, 02:09 AM
  #1705
Regional Moderator
disaster999's Avatar
DTM: haha...thanks for the advice...but i dunno if there is some shrink rap that could completely cover the AA batt...but ill consider your advice...hehe!!
manticore: the remote is using its factory crystals...futaba! so...i think they have the best match...the battery problem is what im concerned! i always have to charge them frequently and its really annoying waiting for them to charge! i believe that M8, 3PJ, EX-1 and other "super computer" remotes use a lot of batt...so...i think adding more should last longer!
disaster999 is offline
Old 11-05-2001, 02:41 AM
  #1706
Regional Moderator
hey....how do you take off the wheel on the on the 3PJ!!!
Old 11-05-2001, 04:33 AM
  #1707
Manticore's Avatar
all about precision. if they want to scale down the cost of the radio set, those bit and p iece are the place where they want to cut cost. Yes they are matched pairs but only up to 1 or 2 digits after decimal. adding one more battery will only boost up the TX range/power but not really give you longer run time. i.e. in serial will give more V but in parallel will give you more capacity.
Old 11-05-2001, 05:41 AM
  #1708
Regional Moderator
thats true!
Old 11-05-2001, 06:29 AM
  #1709
dtm
dtm's Avatar
999- are you using AA Nimh rechargeables? at 1500mah I usually get around at least 5 hours operational time which is good for about 2 days worth of running.... and these are 2 year old batteries. In the long run they work out very cheap!
dtm is offline
Old 11-05-2001, 06:30 AM
  #1710
dtm
dtm's Avatar
Pry off the centre cover on the wheel and it will expose a screw which holds the wheel in place.
dtm is offline
