HK Talk Version 1.1
Old 02-24-2004, 05:58 AM
  #16606
KY9fat's Avatar
Just read the thread... 'Fast' engines only suited in EGR, ACO and not PYC?....He's getting TOO OLD for this hobbie............
KY9fat is offline
Old 02-24-2004, 05:59 AM
  #16607
dtm
dtm's Avatar
Originally posted by oldcake
does any one of you know this teamorionhk?
i think he 9 up very much.
http://www.rcmodel.com.hk/lb5000/top...um=last#bottom
Damn....translate...translate???????
dtm is offline
  #16608
dtm
dtm's Avatar
Originally posted by KY9fat
Hahahahaha...Of cause we know who he is.........
He got a lot of classics like.....Why NTC3 is so fast around corners because of it's flat chassis and the "GROUND EFEECT" it gives massive downforce to the body etc..etc......
Also once suggested that he uses different springs on all for shocks so that it will compensates for the track at PYC.. And he DID used diffent springs....but his car ran like SH!t...
Oh....it's him......MASTER!!!!!!!
dtm is offline
Old 02-24-2004, 06:00 AM
  #16609
dtm
dtm's Avatar
I would agree.....My slow OS runs very well at PYC........but so does my NS3??????
dtm is offline
Old 02-24-2004, 06:01 AM
  #16610
dtm
dtm's Avatar
KY- That lump of metal I bought is a bloody TANK!!
dtm is offline
Old 02-24-2004, 06:13 AM
  #16611
KY9fat's Avatar
These guys are SLOW...I've been using .15 Sirio for ages...Love the TORQUE and the sound...and the BANG...Oh there goes my Con-Rod in million pieces......Should have replaced it after the running in..... .........Strip, clean, shake all the debries out, new Con-ron and off I go again......
And all in PYC
KY9fat is offline
Old 02-24-2004, 06:14 AM
  #16612
KY9fat's Avatar
I'm on it..........
KY9fat is offline
Old 02-24-2004, 06:15 AM
  #16613
KY9fat's Avatar
Post Picture against you Mini-T
KY9fat is offline
Old 02-24-2004, 06:37 AM
  #16614
Manticore's Avatar
Originally posted by kitracer
9 up is too kind to him.
What the f&%k is he? giving out general comments about HK R/C people. Does he know anything?
need to teach him a good RC lesson
oh fuxk ! forget about him ! he is a joke !!
Manticore is offline
Old 02-24-2004, 06:38 AM
  #16615
KY9fat's Avatar
The more I read the more I can't stop laughing...
Here's the Best bit I like and it's in Nicam
Quote:-
For those who can read Chiness..
"用上超大功率的15級引擎,引起機械配搭的問題。
When using powerful .15 engines, the problem it creates for mechanical parts:-
第一:現在的車架是針對12級引擎而設_p,如在用料,動力傳遞等。但是如果
用上15級的超大功率的引擎,好容易做成零件過囝的磨損 ,如轉動齒、傳動軸或帶,bearings,CVDs等。零件加速的磨損可能使到車子難於調教。
1. Nowadays the chassis is designed for .12 engines, e.g. materials, transmissions. If powerful .15 engines are used, it is very easy to ware out the parts like gears, belts, bearings, CVDs, etc.. Fast worn parts made setting the car difficult.
第二:當引擎功率過大,好容易把車架的不良設定,暴露出來,圈速反而慢了。如車架可能過度傾斜,而引_P底板著地而弄_P車呔過彎不抓地。
2. When engine output is too big, it is very easily exposed the badly set chassis, lap time will decreased. Like making the car roll more and making the chassis touch the ground, in-turn making the tire loses it’s grip when cornering.
第三:增大了的引擎功率,做成零件的過大磨損,亦浪費 了一部份的引擎動力。如車呔時常在打滑狀態,加速不快,浪費了動力。增大了的引擎功率給浪費掉。
3. Increase engine power, makes parts wares more so make the engine loses part of it’s power. E.g. Always wheel spins so no accelerations, wasting power. This loses the benefit of fitting a bigger/powerful engine in the first place.
第四:這等15級引擎,未有經過用[email protected]用的測試。用上12 級的物料,祇是加大衝程及燃燒室內的_捫n,引擎未必[email protected]用及可能好run的 擗l不多便玩完或引_P調教困難。
4. These .15 engines haven’t been tested by users. Material used is the same as .12 but only increase in bore and stroke. Engine might not be reliable and “Fun” days wouldn’t last long, or result in difficult to tune the engine.
第于:現在的foam呔,其抓著力可能不足以應付超大功率 引擎。因為,現時的foam呔是針對12級引擎而開發。加速時可能會產生變形,溫度過高等情況。
總括的來說,就像是在一部Corolla四門房車內加入一_紓12 Turbo引擎一樣。生產商祇是注_咩Q潤,一切所引伸出來 滌暋D,閣下自理
5. Form tires nowadays may be not capable of handling these powerful engines. This is because it is designed for .12 engines. The tire may deform when accelerating, overheating, etc.. Generally it is like a putting a V12 Turbo engine in a Corrola. Manufacturer only concerns with their profits and any problem resulted is your problem. "
End of Quote
KY9fat is offline
Old 02-24-2004, 06:39 AM
  #16616
Manticore's Avatar
Old 02-24-2004, 11:43 AM
  #16617
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by disaster999
i wonder what happen to the rest of the gang...so quiet these days!
Very true, maybe they took the weekend off for racing.
Randy Caster is offline
  #16618
LeoChan's Avatar
DTM :
I like your Slow OS engine
because i'm feel turn faster
LeoChan is offline
Old 02-24-2004, 11:46 AM
  #16619
Maybe he doesn't know that sedans are 4wd?
Old 02-24-2004, 12:00 PM
  #16620
dtm
dtm's Avatar
Originally posted by LeoChan
DTM :
That 3 year old MT engine I put on last week was not too bad neither......
dtm is offline
