HK Talk Version 1.1
Old 02-03-2004, 01:26 AM
  #16291
dtm
dtm's Avatar
Originally posted by Randman
Wow... you guys need to stop breaking in your engines at 40,000rpm
haha....I think it is just manufacturing defect.....
dtm is offline
Old 02-03-2004, 02:01 AM
  #16292
Diva's Avatar
Trader Rating: 14 (100%+)
Originally posted by dtm
Can I have your run in conrods??? I can use them for further run ins!!! I normally only replace if I detect wear from the bushing.........
Nah, you need something outside Taiwan to match your LD3.
Diva is offline
Old 02-03-2004, 03:00 AM
  #16293
Manticore's Avatar
sts conrod and novarossi conrod are interchangable.
Manticore is offline
Old 02-03-2004, 03:01 AM
  #16294
Manticore's Avatar
I've seen the brass bushing fall out after break in....my KY case is very special........
you could find any "believe it or not" with KY !
Old 02-03-2004, 03:02 AM
  #16295
Manticore's Avatar
he didnt, he had just messed up his carb needle while running in his engine !
Old 02-03-2004, 03:03 AM
  #16296
Manticore's Avatar
A nice grade of 1000 grit wet n dry paper sorted out the tightness on my Siro .15......
use brasso instead ! sand paper is scary !
Old 02-03-2004, 03:58 AM
  #16297
dtm
dtm's Avatar
brasso takes too long....1000 grit leaves a better finish than original piston sleeve. 2000 grit leaves mirror finish....that what I use for diff rings!!
dtm is offline
Old 02-03-2004, 04:19 AM
  #16298
LeoChan's Avatar
Default PYC
GP car are you ok ?
SAT PYC !!
LeoChan is offline
Old 02-03-2004, 12:09 PM
  #16299
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Nice, I've never tried that either, but these engines have gotten a ton more compression since I got out...
Randy Caster is offline
Old 02-03-2004, 12:13 PM
  #16300
lol, maybe 2 turns too lean.
Old 02-03-2004, 10:52 PM
  #16301
Diva's Avatar
dtm: have you received your royalties
http://www.rctech.net/forum/showthre...threadid=32732
Diva is offline
Old 02-04-2004, 12:03 AM
  #16302
Damn that's a pretty car
Old 02-04-2004, 03:53 AM
  #16303
dtm
dtm's Avatar
Haha.....I did see that. If someone wants to give me USD500 for my chassis I will gladly part with it!!!
dtm is offline
Old 02-04-2004, 04:00 AM
  #16304
dtm
dtm's Avatar
I may not be running EP at the moment...but some new EP toys arrived today!!!
Very nice!!
dtm is offline
Old 02-04-2004, 06:08 AM
  #16305
Diva's Avatar
Very nice!!
Yeah. That's really very nice. Far better than SSG
Diva is offline
