HK Talk Version 1.1
Originally posted by Diva
That's KY's practice
Originally posted by Randman
So Manti, do you remove the conrod after break in as a normal thing?
Oh..My Sirio Con Rod disintergrated a gallon or so after run in with out replacing the con rod.
Originally posted by Manticore
virus? ky shaft got virus?
Regional Moderator
hey..speaking of viruses...hk is pretty messed up ya? you get the chicken flu...then goose flu, now pig flu! the beef in the world have mad cow disease! the only thing your able to eat is veggies! and even those are like...packed with chemicals and shit...
i guess ill just feed of air...wait...even that is polluted! argh..waht could we eat?
Regional Moderator
R/C Tech Elite Member
Originally posted by KY9fat
Normally novarossi is ok....look at the wear on mine and it didn't explode......yet. Not sure about made in Taiwan
Obviously i will replace it if the piston/sleeve was tight before run in as this will give a lot of stress to the conrod during run in.
Nah..I normally replace the Engine after running in
I will check the conrod to determine !
Replacing conrod after break-in is a must. It's because during the process, the bushings of the conrod suffer from heavy loading and hence wear.
That's crazy, I've never had a problem with the con-rod in any engine...
Originally posted by dtm
I've seen the brass bushing fall out after break in....my KY case is very special........
That's cool, I like that on this Palmaris engine, it isn't as tight as some of the others out there, less stress on the con-rod. It's also all aluminum, so heat is not an issue...
