HK Talk Version 1.1
Old 02-02-2004, 08:17 AM
  #16261
Diva's Avatar
Trader Rating: 14 (100%+)
Originally posted by dtm
I would check or calipers...if they are digital then that will be your problem.......
When I was a lad....and an apprentice.....the only digital calipers used in the workshop were Extremely expensive and calibrated very often!! Not your typical Sham Shui Po stuff!!!
I'm using digital one.
Diva is offline
Old 02-02-2004, 08:18 AM
  #16262
Manticore's Avatar
Originally posted by Diva
After 5 tanks of improper run-in (only around 40 deg C), my D5's pin diameter reads 4.23-4.24mm. It's not perfect cylindrical.
dtm: I'll not use your starter box for running-in cuz I have put the D5 on V1 for loaded-break-in next time. Thanks btw.
my D3 ran in at bench less then 35'C for at least 1 litre and when I replaced the conrod before lean it up, it was difficult to put the new conrod in.
low temp run in will make piston/sleeve bed in quicker with very rich needle setting.
Manticore is offline
  #16263
dtm
dtm's Avatar
Originally posted by KY9fat
Good one 4.29-4.30mm
Bad one 4.00-4.10mm
You see...the guys were right on the engine thread....you do need to replace your crankshaft after run in.......now who said that was BS!!??!!
dtm is offline
Old 02-02-2004, 08:20 AM
  #16264
dtm
dtm's Avatar
Thats because you did not use the dremel technique!!!
dtm is offline
  #16265
Manticore's Avatar
virus? ky shaft got virus?
Old 02-02-2004, 08:22 AM
  #16266
dtm
dtm's Avatar
Oh no....."Mydoom" strikes again!!!!!
I told him to email NR with the batch number on the crank...probably find that they forgot to heat treat!!!!
dtm is offline
Old 02-02-2004, 08:28 AM
  #16267
Manticore's Avatar
this virus bit smooth ! it looks very round and even on the wear !
Old 02-02-2004, 09:21 AM
  #16268
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
what did you use to run in your crankshaft?
Beach sand...
Randy Caster is offline
Old 02-02-2004, 09:39 AM
  #16269
Regional Moderator
disaster999's Avatar
we gotta change the crank after run in?
disaster999 is offline
Old 02-02-2004, 05:38 PM
  #16270
Diva's Avatar
I dismantled the motor. Everything is fine except the conrod is fairly easy to be removed. But the situation is not as severe as infected by MyDoom
Diva is offline
Old 02-02-2004, 06:20 PM
  #16271
Diva's Avatar
That's KY's practice
Diva is offline
Old 02-02-2004, 06:33 PM
  #16272
So Manti, do you remove the conrod after break in as a normal thing?
Old 02-02-2004, 07:38 PM
  #16273
Diva's Avatar
Replacing conrod after break-in is a must. It's because during the process, the bushings of the conrod suffer from heavy loading and hence wear.
Diva is offline
Old 02-02-2004, 07:44 PM
  #16274
Wow, I've honestly never heard of anyone doing that...
Old 02-02-2004, 07:51 PM
  #16275
ernestf's Avatar
so far I managed to break in two new engines since I move to Singapore ... it's time to open up the engine and do the same measurement on my Sirio and OS
ernestf is offline
