HK Talk Version 1.1
Old 02-01-2004, 10:46 PM
  #16246
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by Anthony Yuen
Hi Randy,
How is the CGM going ?? How is it compared with your Evo 3 ?? Especially on asphalt track ??
Anthony
Also, I didn't like the Evo 3 very much, it didn't have the steering that I like. Yokomo is my ride.
Randy Caster is offline
Old 02-01-2004, 11:12 PM
  #16247
Manticore's Avatar
Originally posted by ernestf
friends, it's my last day in HK this trip. Only managed to go MK once, and spent some $$. hope i can back and play with you guys next time during my vacation.
all the best !
good luck and stay cool buddy !
Manticore is offline
Old 02-02-2004, 05:06 AM
  #16248
dtm
dtm's Avatar
all the best !
You sound like you are going off to some far away land with no computers and no internet!!!!!
See you next time!!
dtm is offline
Old 02-02-2004, 05:37 AM
  #16249
Manticore's Avatar
See you next time!!
no he is far away from TLC !!
Old 02-02-2004, 06:32 AM
  #16250
KY9fat's Avatar
Angry My NSR12S5
My Crank after run in!
KY9fat is offline
Old 02-02-2004, 06:33 AM
  #16251
KY9fat's Avatar
KY9fat is offline
Old 02-02-2004, 06:35 AM
  #16252
KY9fat's Avatar
And it's not the Connecting Rod!..
Same Con Rod with NEW Crank.
KY9fat is offline
  #16253
KY9fat's Avatar
One More
KY9fat is offline
Old 02-02-2004, 06:39 AM
  #16254
Manticore's Avatar
did you measure pin size of a good one vs the bad one?
Old 02-02-2004, 07:19 AM
  #16255
KY9fat's Avatar
Good one 4.29-4.30mm
Bad one 4.00-4.10mm
KY9fat is offline
Old 02-02-2004, 08:05 AM
  #16256
Diva's Avatar
Trader Rating: 14 (100%+)
Bad one 4.00-4.10mm
How long do you think the new crank will last until it reaches 4mm?
Diva is offline
Old 02-02-2004, 08:07 AM
  #16257
Diva's Avatar
Bad one 4.00-4.10mm
After 5 tanks of improper run-in (only around 40 deg C), my D5's pin diameter reads 4.23-4.24mm. It's not perfect cylindrical.
dtm: I'll not use your starter box for running-in cuz I have put the D5 on V1 for loaded-break-in next time. Thanks btw.
Diva is offline
Old 02-02-2004, 08:11 AM
  #16258
dtm
dtm's Avatar
I would check or calipers...if they are digital then that will be your problem.......
When I was a lad....and an apprentice.....the only digital calipers used in the workshop were Extremely expensive and calibrated very often!! Not your typical Sham Shui Po stuff!!!
dtm is offline
Old 02-02-2004, 08:15 AM
  #16259
Manticore's Avatar
Bad one 4.00-4.10mm
what did you use to run in your crankshaft?
Old 02-02-2004, 08:17 AM
  #16260
dtm
dtm's Avatar
I think he used a grinding stone on a dremel to get that "Speed" effect!!!!
dtm is offline
