HK Talk Version 1.1
Old 10-29-2001, 09:11 AM
  #1591
Manticore's Avatar
Originally posted by dtm
Manticore- You have 666 posts (not for long!) The sign of the devil!!!
Manticore is devil as a matter of fact !
Manticore is offline
Old 10-29-2001, 09:16 AM
  #1592
Anyone know how to change the Eagle power supply to use with 110 V?
Kingcrab is offline
Old 10-29-2001, 05:59 PM
  #1593
Manticore's Avatar
there should have a small metal plate comes together with the power supply. you need to bridge two of the terminals on the input/output port to make ti 110V compatible.
Old 10-29-2001, 06:13 PM
  #1594
Mars's Avatar
Oh my GOD!.... gear it even higher!! You will be able to fry an egg on your motor after you have finished!!
my gearing was not too high last time and the motor was not really hot. I'll check the condition of the brush and the comm and decide whether I should gear it higher
Mars is offline
Old 10-29-2001, 06:17 PM
  #1595
Mars's Avatar
Originally posted by ernestf
u guys want a JMRCA standard stock race next time ????
yeah, why not 23t racing is another kind of fun
Mars is offline
Old 10-29-2001, 06:53 PM
  #1596
Manticore: Bridge over the two terminal that have a red select on the bottom?
Kingcrab is offline
Old 10-29-2001, 08:45 PM
  #1597
Manticore's Avatar
I am not sure about it. Need to look at my supply at home and tell you later tonight.
Old 10-29-2001, 11:03 PM
  #1598
Manticore: Thanks! Please tell me tonight because I'll go to race in Japan tomorrow. I need to change it b4 packing.
Kingcrab is offline
Old 10-30-2001, 01:01 AM
  #1599
dtm
dtm's Avatar
Mars: since you rmotor is a closed end housing. Do you do the water quench run-in that people use to do with the old Tamiya silver cans?
I like the idea of a removable armature to true the comm.... it would all be too easy to fry the motor with a bit of overgearing!
dtm is offline
Old 10-30-2001, 01:53 AM
  #1600
Mars's Avatar
you may laugh, I did nothing to it, just bolt in and run
Mars is offline
Old 10-30-2001, 02:42 AM
  #1601
PeterCheung's Avatar
Post Tires for 1/18.....
How much is the high grip tires for MICRO RS4 in HKD????
PeterCheung is offline
Old 10-30-2001, 04:49 AM
  #1602
Manticore's Avatar
Bridge the terminal with the silver label "Select" which is the far end from the voltage adjusting volume.
Old 10-30-2001, 06:25 AM
  #1603
Regional Moderator
disaster999's Avatar
when you gear the car a bit high, the motor would over heat...would this cause the comm to be burnt too?? (change color)
hey....i found out something...if you dont have a comm lathe...you could get those 1000 sand paper, and sand the comm...just keep turning while sanding and add water when your doing that...the comm could turn out nice and shiny and smooth...a lathe does a much better job...but the method i mentioned saves $$...hehehe..
correct me if im wrong!
disaster999 is offline
Old 10-30-2001, 06:34 AM
  #1604
Manticore's Avatar
The reason why we use a lathe is that we need to cut the comm in almost absolute round to avoid the brushes from vibration. An uneven wore comm surface will cause the brushes vibrate and lost close contact with the comm and therefore slow down speed.
Old 10-30-2001, 07:19 AM
  #1605
dtm
dtm's Avatar
Yes, Manticore is correct. A worn comm will not actually be round. It may look to be round but in actual fact the comm between the different copper segments would have worn down further than the rest of the comm. If you sand the comm all you do is clean up the burnt marks but the comm is still not round. The important part of what the lathe does is make your comm round again so the brushes don't bounce as the motor spins. Bouncing leads to sparks which causes much quicker burning of the comm!
A good secondhand lathe should not set you back too much and in the long run it will work out cheaper!
dtm is offline
