HK Talk Version 1.1
Old 10-25-2001, 10:51 AM
  #1501
dtm
dtm's Avatar
They are Orion Motors!....... Orion make the motors for Hudy.... if look closely you will see the small label "made my Orion!"
dtm is offline
Old 10-26-2001, 07:57 AM
  #1502
Manticore's Avatar
but the big label is HUDY XRAY !
Manticore is offline
Old 10-26-2001, 07:59 AM
  #1503
Manticore's Avatar
Originally posted by Fire
you can use a cordless drill~
999, get the ABC body hole puncher, the one i am using has been at my pit box over 10 years and it is a quickie to make a perfect body hole.
Old 10-26-2001, 09:39 AM
  #1504
Regional Moderator
disaster999's Avatar
nono..its really hard to position the body for 1/12.....i have those dills!
disaster999 is online now
Old 10-26-2001, 01:44 PM
  #1505
KY9fat's Avatar
Drill B4 you paint.
KY9fat is offline
Old 10-26-2001, 05:05 PM
  #1506
Regional Moderator
i did!
Old 10-26-2001, 05:06 PM
  #1507
Regional Moderator
i even trimed the body before i paint....i followed the grooves on thje body...but they dont fit the car....sigh...
Old 10-26-2001, 09:47 PM
  #1508
dtm
dtm's Avatar
You can either use the old body as a guide (if you are spraying up the same body). Or cut out only the front wheel arch, drill the body just to line up that wheel arch and then with the body mounted on the car, mark out the rear wheel arch for cutting.
When you mark out the positions for the holes, make sure the body is horizontal, mark and drill the two holes for the rear first, because these are usually higher and the posts will touch the body first. After drilling these holes, mount the body through these holes MAKE SURE THE BODY IS HORIZONTAL again and mark the front two holes out.
Are you having problems with getting the wheel arches to line up or the four posts to line up with the holes?
dtm is offline
Old 10-27-2001, 08:29 AM
  #1509
Manticore's Avatar
999: go to HPI homepage there is a comprehensive guide on preparing a body.
Old 10-27-2001, 07:25 PM
  #1510
Manticore's Avatar
Originally posted by KY9fat
Drill B4 you paint.
actually you can paint before you make holes.
Old 10-27-2001, 07:26 PM
  #1511
Manticore's Avatar
How about a AC drill???
Old 10-27-2001, 07:27 PM
  #1512
Manticore's Avatar
Originally posted by over gear
I've got shaft! I got FT TC3...
check out rcracing.com, there are a lot of racing clips and most of them are TC3 top drivers. they drive so smooth !
Old 10-27-2001, 08:33 PM
  #1513
Regional Moderator
DTM: well....im having problem lining up the wheels...like...when i trimmed the body, the front and rear wheels fit perfectly...but when i drilled the holes on the body, the front wheels fit...the rear are off, i think from now on, im going to trim the front wheels first, then trim the rear wheels when i have the body on....
Old 10-27-2001, 08:35 PM
  #1514
Regional Moderator
sigh...i bought a spray system yesterday, and bought some paint fro R/C bodies. the paint is from Pactra and it made a mess on the body!!
Old 10-27-2001, 08:39 PM
  #1515
Manticore's Avatar
what did you get from pactra?
