Go Back  R/C Tech Forums > International Forums > Hong Kong Racing
Serpent Nitro Tour 2008 Hong Kong >
Old 12-14-2007, 12:58 AM
kitracer's Avatar
Default Serpent Nitro Tour 2008 Hong Kong
Hope to see many of you.
kitracer is offline
Old 12-16-2007, 11:05 PM
Default serpent tour...
Hi kitracer,
I'm from Malaysia, this is my first time going to Serpent tour in HK.
Maybe we meet b4, i went to the serpent tour in Bankok 2005/2007...
Can pls advice bout the gear ratio, basic setup and tire shore/wear for the track for both 1/10 and 1/8, I'll be racing both class 720 and 960...
thanks in advance, see u there...
ck960 is offline
Old 12-17-2007, 04:02 AM
kitracer's Avatar
Originally Posted by ck960 View Post
Hi kitracer,
Hi there, I am sure we met. I was at Bangkok too.
I have not tried the 720 at this track yet. I will do that next week.
Use the same setting at Bangkok , it works very well at our track but use 1 teeth bigger pinion and 1 teeth smaller spur.
Tire are the same as bangkok too, 38 front and 40 rear. Some guys use 35 / 37 but I think it will be too much traction for the race weekend
I dont run 1/8 so cannot help you on that.
kitracer is offline
Old 12-17-2007, 08:38 PM
thanks for the info... i'll try to recall back what setup i did in Bankok... i ran 710 last time at bangkok
i think will go for wider width will help the conering speed without traction roll
up 1 teeth for pinion is it for both or 2nd speed only?? wow that track must be very long straight, bigger pinion and smaller spur = long top speed
thanks again... see u there...
ck960 is offline
Old 12-17-2007, 10:50 PM
kitracer's Avatar
Last week we had a Open race. I was running NT1, best lap 22.8 sec.
You need to be that range to make the A main.
Bangkok is about 17.5 sec per lap so ACO is better.
kitracer is offline
Old 12-21-2007, 09:47 PM
Default ACO
Hi kitracer,
with all those top drivers from Asia, If i can get into the B main i'll be very very happy
have u test your 720 on the track yet?? any info to share?? whats the average time u get per tank?? i think 5 min will be tough to get...
saw the video already... really big track with smooth flowing corners, only few tight turns, i think will setup my car for more on throttle steering and gear ratio will be biggest pinion and smallest spur for 2nd, 1st gear will try medium first...
We will be there on 9th or 10 Jan to practice hope to see u there...
thanks,
ck
ck960 is offline
Old 12-24-2007, 06:24 AM
kitracer's Avatar
Hi kitracer,
thanks,
ck
I finally tried the 720 after 10 months of idle and I can't believe myself. After 2 tanks and made few setting changes, I made better lap time than my NT1 under same condition !
You will need the 4mm lower chassis and brass front weight. But this may change since during the weekend, grip will be really high.
B main is very good. This is what I hope to get into
making 5 mins is not difficult, but you have to be good on throttle and keep good driving line.
I will be there 11th, I will come by your table and say hi.
kitracer is offline
Old 12-24-2007, 06:19 PM
Hi Kitracer,
wow... great to hear u better ur time, maybe u can think off sticking with the snakes
thanks for the tips, i have the LCG chasis, will try to get the front weight... can please share with me ur setup, hope i can have a basic setup and finetune from there... see u there...
ck
ck960 is offline
Old 12-25-2007, 07:47 AM
kitracer's Avatar
Hi Kitracer,
ck
CK, Have you book a hotel room yet? It will be the Hong Kong Toy fair exhibition during that week so you will be fighting against 150,000 visitors for hotel rooms!
kitracer is offline
Old 12-25-2007, 08:04 AM
thanks for the tips, i'll let my organizer know bout that...
ck960 is offline
Old 12-27-2007, 09:35 PM
Arahawak's Avatar
Trader Rating: 32 (100%+)
Erm, so what is the setup?
is stock setting from the box good to go? 1st time running 720 in ACO and anywhere
is 37 shore good?
Arahawak is offline
Old 12-28-2007, 01:40 AM
kitracer's Avatar
The driver list already filled for 1/8 and almost full on 1/10 and the Thailand Team name is not even on it yet.... this going to be a Good one!
kitracer is offline
Old 12-28-2007, 02:04 AM
kitracer's Avatar
is 37 shore good?
I cannot really say whats good since I just tried few tanks. I used stock setting ( stock shock, droop, camber) plus the option parts ( LCG Chassis and Brass weight) and mid oneway but it was understeering compare to NT1. Then I went to 2degree toe in from 2.5 it was better. and then I switched from DNA body to 3.2 stratus that was Much better this is where I stopped. (I was testing engine as well and clutch soooooo too much in one day)
I got advise from Julius to try the new Steering Block since of smoother steering so I will try this week.
I only used 38 front and 40 rear.
My gearing for my engine Axial 17/22 & 60/55
I suggest Picco use lower gear ratio.
kitracer is offline
Old 12-28-2007, 05:30 AM
kitracer's Avatar
CK, i saw you have 4 countrymen registered. Good stuff
kitracer is offline
Old 01-04-2008, 10:45 AM
kitracer... we r all boost up ready for action
so many racers registered... such a great way to start off a new season...
how ur testing goes with the new stearing block?? any other changes u make to make it better ur time?? see u soon...
ck
ck960 is offline
