Painting Q
Painting Q
So, I've been trying to get a little better at painting and picking up whatever body I can find cheap on eBay. Hence the HPI Beetle I painted a couple of weeks ago.
This time I decided to try to do more than press the button on the top of the spray can and I put in a Parma mask. Everything good with the base coat and then this afternoon I pulled the mask out.
The problem is when I removed the mask a bunch of the glue stayed on the body and didn't come off with the mask.
I tried a fingernail but that just smears it.
I thought about using goo remover, but I'm worried that will take the paint off as well.
Anyone got any good ideas for removing the remaining mask glue without messing up the paint?
Thanks! Sometimes I'm really dense. I've done that before for bad window masks but just didn't put 2 and 2 together.
go to hobbytown; in the paint section there should be a can of ELO; easy lift off. this stuff is palstic safe and will remove any kind of paint from any plastic surface. i've had the same can for 8 years and it still works great!!!! will take tape residue off too. or you can try goo gone.
Thanks for all the suggestions. I used Frog tape and it pulled the left behind goo off pretty well.
