Nexus My first on road car. 1/10 or 1/12 ?
#16
Thanx Chad. I noticed that Nexus don't sell the 17.5 I guess 'll have to order that. getting close to buying time. Any ESC choices you have?
#19
Go with the Tekin RS Pro esc. It is very fast and very tunable with the Hotwire interface.
#20
thanx for all the info guys.
If I purchase the T2R pro I need to know if it is a rubber tire car or foam? Can I use both with it? Which one is better or easy to drive? And why do you guys drive what you drive?
Any plans for a spec class? I want to get my son involved too.
#21
The Vintage Trans Am class is a touring car based spec class. It's a ton of fun. You should check it out also until you get used to the car. Here is the link to the rules, etc...
http://www.usvintagetransam.com/
#22
Well guys I just got a sweet deal on a CRC GEN X 1/12. So I guess I;ll be going the way of the pan car. Look forward to getting some setup tips. Looks like Nexus has everything I need so I know were my money is going
#23
Im not really sure about the t2 pro being a foam or rubber car. I run a T2'009 rubber spec. The reason I run that is because its a great car and because i can get parts for it at Nexus. Another good choice for batteries is a SMC 4100. I think there about $65 a peice at nexus.
#24
What battery do most of you run for 1/12 stock? Are most of you running Lipo's and brushless 17.5 ?
What is a good starting tire combination? It says it's magenta on the pack but it looks black to me.
#25
4000mah 25C 3.7V Lipo Single-Cell Battery for 1/12 (w/ hard case)
Is this one of them all day batteries?
#26
#27
Yes. You just need one battery and recharge it between rounds. If you run the LiPo at Nexus, it will be 13.5 instead of the 17.5. You will also need a receiver pack. I don't run the LiPo; so, you will need to check with some of the other racers for the specifics on setting the car up.
#28
I got this in the mail this past weekend. Any good setups for the Nexus track?
Time to get the electronics. I have to decide with Lipo or NIMH. Is the Novak Millenium PRO still a good charger? Or should i just make the switch.
