SUGARBOWL ELECTRIC AND NITRO AUGUST 3RD
#31
What!
You must be crazy to think foam is ancient!! The reason people choose to run rubber is setup and they last longer per set. But if you pay $32 per set rubber and around $22 for foam set, I can get 3 foam sets to 2 rubber and balance longevity. But for sorry drivers, they chunk to many foams and need rubber tires. Also, foams wear and your setup characteristics change with the wear. People who don't want to spend the time adjusting setup and learning how to tune their car, rubber is for you. Foams give that extra acceleration, speed and the super handling that adds to the ultimate control of you car.
Just a few thoughts!
#32
Well, under that scenario there would be foam for only one other touring class. Anyway, it's not like we're putting our fist down or anything...we're just suggesting what would be best for everyone.
Ideally there would be only 1 type of tire. Last year, we probably averaged two guys per weekend wanting to run foam, and everyone else wanted to run rubber. We ended up putting them together just for the heck of it, but I know the average racer does not like that.
Bottom line is that more people want to run rubber. Only a small amount of guys will want to run mod to begin with, and it doesn't make sense to split them into two classes. Plus, if we have 5 touring classes (including vintage), we are only hurting ourselves.
Frank, I see your point...BUT it makes a lot more sense with 13.5. When running brushless mod with a double-pink foam tire that now comes cut very low out of the box, it's difficult to balance the wear because the side-load put on the tires with a mod motor will tear the tires VERY easily - you don't even have to hit anything! Plus, rubber tire prices are dropping. The new Jaco's are selling for only $29, and we're working on having a local special on the new Sweeps to put them in the $25 range.
But hey, if a lot of guys want to run foam mod, go for it. I doubt that we'll see a 13.5 foam and mod foam class on the same day, though, because I just haven't seen that many people that want to run foam - and it wouldn't be good to let a class run with only a couple of cars.
One foam class and two rubber classes...that sounds fair to me (based on the amount of people that prefer to run each tire). Plus, I wouldn't doubt that most who start out on foam will end up switching to rubber before it's all over with.
-Arun
-Arun
#33
Also, if anyone wants to run brushed in TC, we'll probably allow 23 turn or slower motors to run with the 13.5's. 23 turn motors are readily available from some of the Japanese brands such as HPI, Tamiya, and Orion because these are the stock motors in Japan. 19 turn is too fast to run with 13.5, but I have read that 23t is very similar to 13.5.
#34
#35
If you want to get a picture of the foam situation as it stands now,take a look at the class entry totals from the upcoming IIC in Vegas.
http://www.intchamps.com/registration/entries.php
#36
It would help keep racing close and costs down if everyone has to run the same cheaper Sweep or Jaco tires.
#39
WHAT!! everyone keep saying rubber tires last you can run them week in and week out .... So why would anyone cry about the cost . Now we are running rubber tires ,now you want to make them spec.hell to the naw No spec tires
#41
One problem I can think of is that it might discourage out-of-towners from coming.
-Arun
#43
#45
How is that buying a win ????
Man lets just save everyone some money and buy Tyco cars, thay are all the same ,so thats its fair and no one has to fine a setup change there car or do any of the other stuff that makes it racing ... Now thats fair
