Technical Assistance
Question to all. I just got a new motor for my drift car. it's a 15T motor. My ESC is a Keyance exstraight that's suppose to support all motors. I soldered my connectors on my motor, hooked it up, and it doesn't work. I'm pretty sure I didn't miss a step so my questions are as follows: 1) Did I miss a step? 2) Is there a way to test this motor to see if it's defective or not? I checked my soldering job with a multimeter and that's fine. There's also continuity between the two connector points so the internal side of the motor is still wired ok. But when I go to hook it up to the ESC, turn it on and try to run it, it just sits there.
Ideas? Arick |
have u properly set up the speed controller?
Run the leads from the motor to you battery directly and see if it runs. Put your voltmeter on the motor leads from the speedo with the batteries in turn everything on and see if you have voltage from the speedo.
Got it working. Thanks. Something screwie with the connectors.
brushless
hey arick, this is george, are you hooked on tc know? i hope so. i wish i would have brought the ready to run car so we could have all run together. oh while im thinking about it, i know you are going to buy a real touring car but if you want to use or buy my ready to run car until you decide which real car to buy, just let me know. it just sits on the wall.
