Go Back  R/C Tech Forums > Commercial/Retail Forums > Gearbest.com
My review of the HG P601 from GearBest.com >
Old 08-20-2015, 07:18 AM
  #16
SteveM's Avatar
Trader Rating: 164 (100%+)
You should date and sign the inside of the body and ask that those that receive it next do the same before sending it onto it's next destination. Sort of a traveling review blog.
SteveM is offline
Old 08-20-2015, 10:13 AM
  #17
hotrod87's Avatar
Trader Rating: 252 (100%+)
Done deal. Great idea. We'll see how far she goes
Inside body will get sig,date and state your in and a sheet of paper with the mods done by each individual. As well as hopefully a video from each.
hotrod87 is offline
Old 08-20-2015, 12:48 PM
  #18
hotrod87's Avatar
Come on guys lets get a list going.
hotrod87 is offline
Old 08-20-2015, 01:11 PM
  #19
R/C Tech Elite Member
TIME MACHINE's Avatar
Trader Rating: 73 (100%+)
I'd love to be a part of this great idea, but I just closed last week on a second home and I'm selling my current one. I just don't have time for RC like I'm used to.....and it kills me!
TIME MACHINE is offline
Old 08-20-2015, 01:25 PM
  #20
hotrod87's Avatar
Maybe it'll come around a little later.
hotrod87 is offline
Old 08-20-2015, 06:59 PM
  #21
hotrod87's Avatar
Whos next ?
hotrod87 is offline
Old 08-20-2015, 07:18 PM
  #22
hotrod87's Avatar
Like I said in the review afterthought i will be trimming the rear bumper,raising the body mounts a little bit more and will also rebuild the shocks to hopefully get them a little smoother.
I also noticed the 6x6 rear axle has the frame extended basically and wondered how it would do as a 4x4 or with the addition of another rear extension and axle. I love that the axles can pretty much be added forever with the way they are designed.. i picture a 8x8 with 4ws. Hmmmmm
hotrod87 is offline
Old 08-20-2015, 09:04 PM
  #23
mkiiina's Avatar
Trader Rating: 71 (100%+)
I'd be in as well. The P402 was interesting and I passed that on to my local Land Rover crew to run. If I can find 2 more tires I can upgrade them to the stock SCX10 wheels and tires and I'm sure I can find one or 2 more parts
mkiiina is offline
Old 08-21-2015, 04:27 AM
  #24
hotrod87's Avatar
Sounds good. I'm hoping to leave stock electronics in it unless they die ,as a test of durability. Its nice that theres a plug for chanel 4 it's labeled so you could add a shift servo.
hotrod87 is offline
Old 08-21-2015, 05:09 PM
  #25
flou's Avatar
Trader Rating: 18 (100%+)
Yep. According to the box that came with the 401 it can be extended up to a 10x10.the 401 definitely needs the servo mounted on axle. The frame gives to much so you lose about half the steering. Was going to ask you guys that know a bit more if those axles resemble another brand so I can get the servo mount.if not is fabbin time
flou is offline
Old 08-21-2015, 06:52 PM
  #26
hotrod87's Avatar
I'll take a closer look at axles as far as sefvo mount but these are differeent than any others I've seen. I started with the rear shocks to smooth them out as 5 of the 6 are sticky. Very interesting design. No oil just a greased shaft so I'm trying to see how i can smooth then out. One was missing the collar for the spring at the top.a little extra grease helped one but not the second one. Back to the drawing board.
hotrod87 is offline
Old 08-21-2015, 07:03 PM
  #27
hotrod87's Avatar
I had seriously though about pulling off the frame extension and rear axle and using the wraith cage thats modded for an scx10 frame on the p601 chassis for a 1.9 build.
hotrod87 is offline
Old 08-21-2015, 07:18 PM
  #28
Gearbest1's Avatar
Default p601 lower price than regular
The p601 exists lower price than ever...
http://www.gearbest.com/m-promotion-...htm?12321412#5
You can click it and find the fact!
Gearbest1 is offline
Old 08-21-2015, 07:24 PM
  #29
hotrod87's Avatar
Thats a good price for what you get. It really is a fun truck.
hotrod87 is offline
Old 08-21-2015, 07:47 PM
  #30
flou's Avatar
The axles on these remind me of what's on the big trucks I deal with at work. Almost like a MACK or something. But they are neat.
flou is offline
