FSEARA 2009 Season Info
#62
Daytona Race up-dates.
1) ROAR has lowered TC min. weight to 1420 grams or 50.089 ounces. Our current min weight is listed at 51 ounces. We WILL LOWER the weight to the new Roar spec.
2) Would like to Thank Novak Electronics for again sending a box of prizes for the 17.5 class. This class is open to any motor. The prizes will be awarded to the highest finisher WITH a Novak Motor.
3) All Host Tracks please make sure that your ROAR membership is current. YOU MUST BE A ROAR TRACK TO HOST A RACE.
4) All racers attending the series MUST also be a ROAR member. Membership can be purchased on line/mail thru ROAR, or at track thru the host track/series on the day of the race.
#63
#65
The Executive committee has approved the following rules deviation recommendation from the Electric On Road Class Committee.
Rule 8.10.5.1 minimum weight for T2 Touring Car has been deviated for the Electric On Road Paved Nationals, Hobby Town USA - Frederick, Oct. 1st - 4th. The min T2 Touring Car weight to be used for this event will be 1420 gr.
Tony,
I don't care about the weight we use for the series. But the rule for weight was a deviation for the race in Maryland only. I took this off the ROAR web site.
Here is what the ROAR rule says:
8.10.5.1 Dimensional Specifications:
Item Limit Specification
Length (B) Maximum 460 mm
Width With body Maximum 195mm
(see Note 1) Without body Maximum 190 mm
Height (C) Maximum 190 mm
(with 20mm blocks under chassis) Minimum 130 mm
Wheelbase (A) Maximum 270 mm Minimum 250 mm
Weight Minimum – Foam 1418 gr Minimum – Rubber 1500 gr
Maximum – Foam 53 mm
Diameter Maximum – Rubber 50 mm
Minimum 47 mm
Maximum - Foam 28 mm
Maximum - Rubber 26 mm
Wheels
Width
Minimum 24 mm
Diameter Maximum – all types 67 mm Minimum – Rubber only 63 mm
Tires Maximum 28 mm
Width Minimum 24 mm
Chord Maximum 40 mm
Width Maximum 190 mm
Length Maximum 40 mm
Rear Wing (see
8.10.5.8 below) Side dam Height Maximum 20 mm
Note: Vehicles must comply with both specifications during a single inspection.
8.10.5.2 Tire type:
Carpet surfaces: Foam and or Rubber tire.
Paved Surfaces: Rubber only.
Capped tires are not allowed on any surface.
8.10.5.3 Battery Cells: Six cell maximum or 2s, 7.4v nominal lipo battery
8.10.5.4 Transmission: Single speed only
8.10.5.5 Front and Rear suspension: Independent.
8.10.5.6 Drive: 4WD only.
8.10.5.7 Body rules:
Bodies must resemble 2 or 4 door cars that have raced in a Touring Car series.
See Global Body Specifications below.
Wheel arch cut-outs: Maximum 9.5 mm over tire diameter.
Please let us know what you decide.
Thank You
#66
After the Club Race on Saturday the 26th, what time will the gates be closing?
#68
STRICKLAND
Greg Jr,Gate will close at 5:00 pm.
Just to remind every one we will have a club race Saturday starting at 10:30 am.
Gate will open at 7:00 am practice from 8:00 to 10:00 am. Entry fee $10.00
Optional class will be World GT 13.5 1 cell.
Mike Bean
MB Racing
info:386-451-4486
Mike Bean
MB Racing
info:386-451-4486
#70
Wow! That worked great. Thank you for the fast and definite response. What time do the complimentary foot rubs begin?
#72
#73
Looking forward to the start of the new season. All I know is no ice throwing this time at Buca De Bepo!!!! That guy that someone (not mentioning names!) hit last time was pissed!!!!!!!!LOL
