MDI Carpet Racing
#17
Thank you to all our friends & family!
On behalf of MDI RACING, we would like to thank our many friends and family who helped us bring a permanent carpet track to South Florida. We look forward to sharing many years of enjoyment and thrills.
Sincerely,
Steve & Les
Sincerely,
Steve & Les
#19
Doug, depends on what tire choice. Foam or rubber, and what type of rubber. I will post my Rubber Setup
Front
60 wt
Yellow Spring
3 hole
0 inboard and outboard toe
8.5 castor
Competetion Sway bar
# 2 Shock Tower mount
#2 or inside hub mount
#1 or upper arm mount
Rear
60 wt
Red Spring
3 hole
2 inboard and 2.5 outboard toe
No Sway bar
#1 or inside hub mount
#2 or upper arm mount
That got in in the ballpark, the car was loose, but easy to drive. I am going to try a little lighter oil, and the regular sway bar.
Front
60 wt
Yellow Spring
3 hole
8.5 castor
Rear
60 wt
Red Spring
3 hole
No Sway bar
#20
I would be very weary of any setup info from that Spooky guy!!!!! LOL!
Hey Spooky, my box should be here Friday the 21st. Hope you gots a fat wallet!! Congratulations to the MDI team for finally bringing to town what everyones been wanting Indoor Racing! They've done their part now we need to do ours. Lets get out there and support the track and the shop and lets keep them running for a long time to come.
Track looks great and it requires a little bit of "wheeling"!!!
SWEET!!!!!!
By the way TeamButter just celebrated it's first National Championship!!! Congratulations to Team Driver Alex "Elian" Lopez for winning the hotly contested 12th stock class at the nats! Way to go Alex! TeamButter is in Da' house!!!!!!
SWEET!!!!!!
#21
Thanks Parkay....
Hey I missed the state race this weekend with a nasty headcold. Russ was at the rug, and we had some pretty good racing. Seriously Mike, if there are some batteries in that package... I have a home for those too. I htink I may practice tuesday night, You in ?
#22
Great Track
Ran for the first time at the new indoor track. What a nice track, fun to run and my car didn't get distroyed! Guys at MDI did a great job and lets all support them and keep this track running for a long time!!!!
#25
Hey Spooky sorry I didn't respond sooner. I am going to be there Saturday Morning around 9:45 or so. Can you make it? Other wise let me know when you are heading to the track. As far as the "care" package I will save anything I see for you.
#26
tc3 carpet setup
Can some one give me some advise on setting my TC3 for carpet. I am going to start with the manual's set up but if someone with experience can give me a heads up that would be a big help.
#27
tc3 carpet setup
#28
Tim, Thanks for the kind words but I have a long way to go to catch you guys!
jhort, I have a TC3 that ive started to play with there and this is what i have so far:
front:
copper spring, 40wt oil, 2 hole piston
inside hole on shock tower
front sway bar
0 degree caster
rear:
gold spring, 40wt oil, 2 hole piston
outsitde hole on shock tower
no rear sway bar
3 degree rear toe
hope this helps,
Doug
front:
front sway bar
0 degree caster
rear:
no rear sway bar
3 degree rear toe
hope this helps,
Doug
#29
INDOOR CARPET TRACK IN PALM BEACH
ATTENTION!!!!! ATTENTION!!!!!
Everyone interested in running in an indoor carpet track come check out MDI Racings Track. Air conditioned, inside pit-space, power, food and on site hobby shop. 1/10th scale touring sedan stock and 19 turn foam as well as 12th scale stock and 19 turn.
Also coming soon...indoor carpet oval racing!!!
Tourning car oval, 10th scale oval, 12th scale oval, and several other oval classes.
Come check it out and have some fun!
http://www.mdiracing.com
