MN Electric Off Road Series
Old 03-16-2011, 04:39 PM
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Default MN Electric Off Road Series
Yes, you heard correct the MN Off Road Electric Series Coming to a Track near you this summer.
Check the Cal.. http://molzermoweryracing.com/race_news.htm
Single day races. Most running on Sunday.
Looks like dates have locked in... mark your cal's.
May 15th MMR
Club Race Points Dates must fall between April 23rd - May 28th : Email, link or paper results are fine. make sure you note name and class raced so we can easily verify. If no results a email from the Track RD will be acceptable.
June 12th Full Throttle
Club Race Points Dates must fall between May 16 - June 11th: Email, link or paper results are fine. make sure you note name and class raced so we can easily verify. If no results a email from the Track RD will be acceptable. You can not use the same results as race 1
July 16,17 Starbuck. MN State Champs
Club Race Points Dates must fall between June 13th - July 15th : Email, link or paper results are fine. make sure you note name and class raced so we can easily verify. If no results a email from the Track RD will be acceptable.
August 7th LSRCC
Club Race Points Dates must fall between July 18th - August 6th : Email, link or paper results are fine. make sure you note name and class raced so we can easily verify. If no results a email from the Track RD will be acceptable.
September 18th Teas
Club Race Points Dates must fall between August 8th - Sept 17th: Email, link or paper results are fine. make sure you note name and class raced so we can easily verify. If no results a email from the Track RD will be acceptable
We may reduce the list as we get classes figured out across the state. We would like to have more in each class & less classes for better deversity through the heats and mains.
Short Course RTR Brushed: Must have oem Brushed motor...( this class is to include the MMR Spec racers and the Spec racers from Duluth plus allow any new racer with a brushed RTR ShortCourse a place to play)
Short Course Open, ROAR Tire, Wt , Body, and Battery rules( 2s hardcase only).. No 1/8th converted chassis, or 1/8th tire and wheels will be allowed in this class.
2wd Buggy Open, ROAR rules for open 2wd Buggy, Lipo must be hardcase.
2wd Stadium Stock, 17.5 Brushless or 27 turn Brushed, 7.4 volt battery source Lipo must be hardcase.
4wd Open Buggy, ROAR rules for open 4wd Buggy, Lipo must be hardcase.
1/8e( may be limited or not allowed at some tracks) ROAR rules for wt and power source. Most tracks will allow soft packs but may require approval for saftey on indoor tracks.. 4s Max, If over motored you may be asked to motor or gear down, RD Discretion.
4x4 Short Course. This is a provisional class and will be run based on enough entries in the class, We will strictly follow ROAR rules for Motor and Battery, 2s only and max motor size of 550.
2wd Stadium Open, This is a provisional class and will be run based on enough entries in the class, ROAR rules for open 2wd Stadium Truck, Lipo must be hardcase.
2wd Buggy Stock, This is a provisional class and will be run based on enough entries in the class17.5 Brushless or 27 turn Brushed, 7.4 volt battery source Lipo must be hardcase
If you race a class you do not see on this list as long as we have 5 in each class we will do everything we can to run that class also
After Race 1 we will start seeding heats based on your points position. Resorts will be done after rd 2 as long as time permits on race days.
Qualifing will be 3 rounds followed by Mains. We will race rocket round for qualifying. Qualifiers will be 4 or 5 minutes long depending upon entries and time requirements.
All Mains will be planned at 9 minute race dureation, We will bump from lower mains, Single or double bump depending on number of racers in class.
If weather becomes a issue we may reduce the number of qualifying rounds done. But we will do everything possible to race in the scheduled time. IF the mains rain out we will use qualifying position for points in the series. If we lose the entire day we will work to reschedule the race in the next following weeks if possible.
http://www.roarracing.com/downloads/..._Rule_Book.pdf
Series will consist of 5 races, 1 throw out.. 10 points for running a club level race between each round. Total of 50 club points available regardless of class or finish position at your local track.
More info coming in the next month....
A MMR Production
Attached Thumbnails MN Electric Off Road Series-mnoffroadelectricseries.jpg   MN Electric Off Road Series-offroad.jpg   MN Electric Off Road Series-offroadavi.jpg   MN Electric Off Road Series-mnoffroadelectricseriesdates.jpg
ammdrew is offline
Old 03-16-2011, 04:44 PM
awesome!
onroad dude is offline
Old 03-16-2011, 04:47 PM
johnnyshore's Avatar
Trader Rating: 75 (100%+)
Best news I've heard all year!!!
johnnyshore is offline
Old 03-16-2011, 05:20 PM
Jakesterama's Avatar
Trader Rating: 68 (100%+)
Awwweeeesome!!!!!
Jakesterama is offline
Old 03-16-2011, 05:32 PM
haywood's Avatar
Trader Rating: 49 (100%+)
Default Electric
Guess I'm getting back into off-road!
haywood is offline
Old 03-16-2011, 05:45 PM
Tennis91's Avatar
Trader Rating: 21 (100%+)
hell ya!! hope there is 4x4 short course!!
Tennis91 is offline
Old 03-16-2011, 08:32 PM
SkarTisu's Avatar
Very interesting!
SkarTisu is offline
Old 03-17-2011, 06:41 AM
FLHX1550's Avatar
A MMR Production
Does the track have to be one of the "series" tracks?
FLHX1550 is offline
Old 03-17-2011, 08:12 AM
ammdrew's Avatar
no but it does have to be a club race, not a two day, or larger event.
ammdrew is offline
Old 03-17-2011, 08:25 AM
ABspeed's Avatar
Great work to Andrew and all involved thus far, I whish I had thought of it myself.
This will for sure be huge! I know for fact I will attend as many as possible.
ABspeed is offline
Old 03-17-2011, 09:19 AM
ABspeed's Avatar
Man, I am still just amp'd about this!
ABspeed is offline
Old 03-17-2011, 10:18 AM
Trader Rating: 30 (94%+)
Looking forward to this!
Rocky8333 is offline
Old 03-17-2011, 10:25 AM
Sideways_1's Avatar
Trader Rating: 141 (100%+)
Classes would be good so Bangle can decide on what to buy...lol
Sideways_1 is offline
Old 03-17-2011, 11:25 AM
SkarTisu's Avatar
The point bonus for attending any club race is novel! That's a neat idea.
SkarTisu is offline
Old 03-17-2011, 06:33 PM
DriftDreamer06's Avatar
what a great idea! great to see the tracks that are involved! 10 points for grass root racing awsome!
DriftDreamer06 is offline
