tb03 cvd ?s
Old 10-07-2017, 06:29 AM
Default tb03 cvd ?s
What length cvds go with the stock plastic ball diff? Also is the aluminum diff joints use the same cvd length as the plastic?
Rcaddicted85 is offline
Old 10-07-2017, 06:31 AM
I also need to get spare diff springs and the tb03 ones are non existent, do any other chassis diff springs fit?
Old 10-08-2017, 09:32 AM
b20btec's Avatar
Download the manual, should cover most of your questions.
b20btec is offline
Old 10-08-2017, 10:08 AM
I have it and says 46 but I've heard the aluminum diff r diff and I'm ordering them n cvds together so wanna be sure
Old 10-08-2017, 03:08 PM
b20btec's Avatar
I have a spec r gear diff with R1 works cvd
b20btec is offline
Old 10-08-2017, 11:37 PM
2.0mm screw/nut/spring is same for all Tamiyas.
Original dogbones are 45mm, both 44 and 46mm fit with plastic ball diff, with gear diff 46mm may be too long. Same with alu ball diff, which needs to fit plastic protector on shafts
Papi is offline
