Roche Rapide F1 Evo
#106
The Gravity tires have a little less overall traction, but are decent once they are prepped. They are couple tenths slower that CRCs. Kit setup on gray carpet should be in the ballpark. You will want to scuff the shine off the contact patch or your first experience will be miserable.
Have a set of the CRC premounts on the way.
Saturday is race day but Sunday I'll be able to get a good practice day in with the track grooved in. Want to play around with pod droop because with the stock shock length at 63.5mm and a pod height of 4.6mm I have 1.4mm of droop.
#107
Just need to paint the body and add some weight.
#109
Roche USA has them.
#113
God that Roche is sexy.
#114
Very nice looking F1Car
#117
Any ETA when 310167 will be available in the US store. Running on a medium grip grey CRC carpet track without a subfloor and a few bumps so I'd like to try the extended shock.
#119
R/C Tech Elite Member
As an alt.. I'd recommend you just look at either drilling the piston or running a lighter oil
I've only been able to successfully run the kit/soft spring
I've only run inline so far on black crc carpet
