Like Tree185Likes
Roche Rapide F1 Evo
Old 11-08-2017, 08:38 AM
  #61
aracefan's Avatar
Trader Rating: 56 (100%+)
Originally Posted by liljohn1064 View Post
Where does one find one of these unicorns?
Originally Posted by hanulec View Post
Uni-what? Cars are around... I think you've been sleeping
50x F1 Evos have come and gone at Roche RC USA. More are on order.
I tried to find where to order one a week or two ago, and had no luck... went ahead and got the F6.
hanulec,
I clicked on your link in your sig but still found nowhere to actually order - and no instructions on how to order either. So, do you have to send an email that you want one and wait for a reply?? Just curious, as I would still like one of these.
Thanks in advance.
aracefan is offline
Old 11-08-2017, 09:24 AM
  #62
Trader Rating: 18 (100%+)
http://shop.rochercusa.com/index.php?route=product/product&product_id=386
aracefan likes this.
iTz Nicholas72 is offline
Old 11-08-2017, 09:54 AM
  #63
aracefan's Avatar
Thanks! I'm not normally "internet challenged".
gabc likes this.
aracefan is offline
Old 11-11-2017, 12:24 PM
  #64
Default Setup
Any chance that you can post the setup for this hot rod?
Originally Posted by sg1 View Post
The Roche F1 ran well all weekend at the Halloween Classic!
Took a TQ and win with it!
Attachment 1448592
JoeRocket is offline
Old 11-11-2017, 07:25 PM
  #65
Kevin CBR's Avatar
[QUOTE=gabc;15070952]Thanks Panda! Any idea how many additional mm this will give me over the stock ones?
The aluminum rear pod was thinner than the graphite so the axle was lower to the ground. Don't remember the difference it gained. Just remember it got me to 5.0 ride height as I was running outdoor.
Panda
Kevin CBR is offline
Old 11-11-2017, 09:11 PM
  #66
gabc's Avatar
Thanks Panda, I'll check the rear pod out.
Gab
gabc is offline
Old 11-11-2017, 09:12 PM
  #67
gabc's Avatar
Hey Barry, good to see you here! 😀
Gab
gabc is offline
Old 11-13-2017, 08:20 PM
  #68
Any chance we'll see a USA Spec Evo with the Aluminium chassis?
Old 11-13-2017, 08:54 PM
  #69
hanulec's Avatar
Trader Rating: 27 (100%+)
Doubtful
Unless it is faster
Don't even have production chassis yet...
hanulec is offline
Old 11-14-2017, 04:55 PM
  #70
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The current answer is: In my hands. Thanks ActivRC.com
JS and aracefan like this.
liljohn1064 is offline
Old 11-15-2017, 04:04 AM
  #71
Alu chassis still prototype, should be release soon!
nicoo2k4 is offline
Old 11-15-2017, 05:54 AM
  #72
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
I never made a set up sheet, but I can give you a few things I did that worked:
Front
9* castor
2* camber
.018" assoc. springs with 1.5mm sag
3/4 SXT sauce
sidewalls glued to seam
1mm shims on axles
3oz. weight in front
lowered upper graphite plate 3mm to change roll center
Protoform wing
Center
CRC shock with 42.5wt and red spring
1.5mm droop
.45 CRC side springs
15K Kyosho grease in 1 tube and 30K Kyosho grease in the other tube
Rear
Fenix gear diff with 30K Kyosho Grease
Protoform wing mounted as low as possible and as close to rear axle.
Team Scream 25.5
WTF fan on top of rear pod
Full SXT sauce
Montech '15 body
liljohn1064 and aracefan like this.
sg1 is offline
Old 11-15-2017, 09:24 PM
  #73
Thanks. I am building mine later this week. I will keep some of those tips in mind when building it.
Front
9* castor
2* camber
3/4 SXT sauce
1mm shims on axles
Protoform wing
Center
1.5mm droop
Rear
Team Scream 25.5
Full SXT sauce
Montech '15 body
Attachment 1450442
Old 11-16-2017, 07:58 PM
  #74
gabc's Avatar
May I know what's the reason behind this, and how this affects handling? Thanks!
Gab
Attachment 1450442
gabc is offline
Old 11-17-2017, 01:38 AM
  #75
hanulec's Avatar
Gab
its to get thicker but not too think -- ie both of heavier weights in both tubes
the thicker dampening slows reactions slightly and helps the car keep its 'set'
hanulec is offline
