Like Tree185Likes
Roche Rapide F1 Evo
Old 10-18-2017, 07:14 AM
  #31
idbdoug's Avatar
Trader Rating: 35 (100%+)
Originally Posted by gabc View Post
Thanks for offering sg1!
I just got the Xray bushings n spur. Will try them out n update the results.
Please refer to the photos n video. It's stock setup except i used shorter 10mm front standoffs.
Note that during my first run, the track had a left turning high speed sweeper. Hence car rolled right. Thus, you'll notice that the graphite pattern chassis protector has most of its wear on the right side too.
YouTube video: https://youtu.be/VMDpx17UroA
If you have too much steering travel some rims(as well as some tires) might rub on your arms and I believe this is what is happening with your car. Try spacing out your tires with shims or decrease your steering travel.
idbdoug
idbdoug is offline
Old 10-18-2017, 07:22 AM
  #32
idbdoug's Avatar
Originally Posted by sg1 View Post
gabc...
I posted a pic of my old car on the other thread so we don't clutter this one up... lol
sg1 you have pm
idbdoug
idbdoug is offline
Old 10-19-2017, 08:36 AM
  #33
gabc's Avatar
These battery nuts match too:
https://www.amainhobbies.com/sworkz-s104-aluminum-battery-holder-nut-4-swx-330338/p267425
Originally Posted by Raman View Post
Gabc- Brilliant idea .. thumb nuts to secure the top plate.. anyone make matching red anodized ones?
gabc is offline
Old 10-19-2017, 08:50 AM
  #34
gabc's Avatar
Thanks for the tips Sg1! I'll try each one!
I'm new to F1 n i came from off-road background. I've got lots to learn. If you don't mind sharing what each of your tips does I'll really appreciate it!
A few things I seen you may want to try....
-remove spacers from rear wing mount or use much shorter (bring wing closer to rear axle)
-remove shim from under steering block (add droop)
-less steering turnbuckle angle (change Akerman)
-add weight under bellcrank (2oz. min.)
-Try batteries inline
-Try raising shock at upper pod plate mount
gabc...
Thanks for the tip idbdoug.
I'm running kit front white springs. Anyone knows what hardness those are?
I've got a set of 4 pairs of different hardness tamiya front springs. Silver, gold, red n black. Which one will be a good choice?
Originally Posted by idbdoug View Post
If your not running a soft kingpin spring a softer kingpin spring might also help
idbdoug
I agree, I run Assoc. .018" and have even tried .016" with 30K grease on the kingpins
gabc is offline
Old 10-19-2017, 12:27 PM
  #35
Raman's Avatar
Trader Rating: 60 (100%+)
Perfect, thank you. Prefer those since they don't have writing on them
Raman is offline
Old 10-22-2017, 05:26 AM
  #36
nogarats's Avatar
I got 2 graphite diff and both of them, the tip pulled off...
has this happened to anyone but me?
I am kind of reluctant to get another one...
Nog.
nogarats is offline
Old 10-22-2017, 06:11 PM
  #37
Khador12's Avatar
I am picking up Rapide EVO and noticed motor fans be mounted on them. Attached are two different ways I have found to mount them. Which one would work better? I also seen one where someone had prototypes of 3D print mounts that go where the stand offs for the rear wing mount are.
Khador12 is offline
Old 10-22-2017, 06:19 PM
  #38
Trader Rating: 9 (91%+)
I personally use the R1 Band that goes around the motor. Puts the fan right on the motor openings. Fan on endbell side works, but I dont think it is as effective. As far as I know, the roche doesnt have a 3d printed rear mount/diffuser
Johnny Carey is offline
Old 10-22-2017, 07:11 PM
  #39
Fredp1's Avatar
Nog.
I've heard of other people, (including myself) , having the same problem with other brands of axles too.
Also be careful you are not way over tightening the axle as it will may be the cause of your problem.
Just CA the tip back in again and it try it again.
Fredp1 is offline
Old 10-22-2017, 07:52 PM
  #40
Khador12's Avatar
Noticed that in the pictures of your car from IIC. Looks like it works very well.
Johnny Carey likes this.
Khador12 is offline
Old 10-23-2017, 02:11 PM
  #41
hanulec's Avatar
Trader Rating: 27 (100%+)
Nog.
Never heard of that before...
Please take some pics and send it to whomever you bought it from for help...
hanulec is offline
Old 10-23-2017, 04:25 PM
  #42
robk's Avatar
Trader Rating: 22 (100%+)
Nog.
This can happen with pretty much any brand except Tamiya, which is all steel back to the hub. I have done it with other brands. You need to drill and pin the threads. I have used a small drill bit and the same size music wire. CA the wire into the hole oversized, and dremel off the excess. No more loose thread.
Rick Vessell likes this.
robk is offline
Old 10-24-2017, 01:04 PM
  #43
Khador12's Avatar
Would a Hobbywing XR10 Pro Spec be enough esc for 25.5 F1?
Khador12 is offline
Old 10-24-2017, 01:17 PM
  #44
hanulec's Avatar
Yes... Perfect
hanulec is offline
Old 10-24-2017, 01:51 PM
  #45
Khador12's Avatar
Thanks Mike. Good luck this weekend.
Khador12 is offline
