Roche Rapide F1 Evo >
Roche Rapide F1 Evo
Like Tree253Likes
Roche Rapide F1 Evo
Old 10-03-2017, 07:09 AM
  #16
Raced my new Evo Sunday on fresh black carpet; 571/572 tires, front tires glued. 1 camber, 3 caster, 1.5mm pod droop, otherwise kit setup. It was quick & stable, very nice to drive.
mariob62 is offline
Old 10-03-2017, 06:40 PM
  #17
what wings work on this chassis?
dman18t is offline
Old 10-05-2017, 09:12 PM
  #18
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Any does Tamiya type f1 cars. Popular manufactures include protoform and Mon-Tech
Quinny45 likes this.
hanulec is offline
Old 10-05-2017, 10:01 PM
  #19
+1 on the Montech.
mariob62 is offline
Old 10-11-2017, 08:23 PM
  #20
gabc's Avatar
Trader Rating: 14 (100%+)
Default Pivot ball bushing, spur gear
Ran the Roche 2016 last night in stock setup on a high grip asphalt track. I'm not sure if i should post this in the 2016 thread or here, but i really need some help.
1. Front arms kept hopping like rabbits on steroids during high speed corners with snapping sound of metal rubbing against metal. I believe it's the king pin rubbing against the pivot balls.
(All pivot balls are free with no binding. 7k shock oil on the king pin shaft.)
2. I used pliers to pinch the front arms pivot ball bushing to remove the binding. I think i overdid it. Now the pivot balls pop out very easily. Is there a better solution? I've read in the Roche 2016 thread that Xray bushings will fit. Is this a good solution?
3. Stripped the spur. Noticed it's not perfectly centered. Is there a better alternative?
Thanks very much in advance!
Gab
gabc is offline
Old 10-12-2017, 04:53 AM
  #21
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Gab
Granted this is for carpet... But...
I added weight under the bell crank, approx. 2 oz. of tungsten
I also set it up for 1.5mm of droop in the front.
With the 16 kit I had to go to shorter standoffs to gain ground clearance.
I haven't had problems with the pivots popping out, so I'm not sure about that...
I noticed the spur was running out also, I use a Kimbrough 92 when I run a ball diff. 99% of the time I use a gear diff with a 92
sg1 is offline
Old 10-12-2017, 07:16 PM
  #22
gabc's Avatar
Thanks sg1! Will try that.
Is the hopping front wheels n rubbing metal sound due to the front being not heavy enough?
Where i am i don't have easy access to Kimborough spurs. Only Xray n Roche spurs. Will the Xray work better? What is the go-to spur for this car? Thanks!
Gab
gabc is offline
Old 10-13-2017, 04:27 AM
  #23
sg1
sg1's Avatar
Gab
I'd try the X-Ray ones.
If you wanted I can ship gears to you.
Not sure about the metal sound, are you sure it's from the front suspension?
Can you post a picture of the set up?
sg1 is offline
Old 10-14-2017, 05:54 AM
  #24
gabc's Avatar
Thanks for offering sg1!
I just got the Xray bushings n spur. Will try them out n update the results.
Please refer to the photos n video. It's stock setup except i used shorter 10mm front standoffs.
Note that during my first run, the track had a left turning high speed sweeper. Hence car rolled right. Thus, you'll notice that the graphite pattern chassis protector has most of its wear on the right side too.
YouTube video: https://youtu.be/VMDpx17UroA
gabc is offline
Old 10-16-2017, 04:03 PM
  #25
Raman's Avatar
Trader Rating: 73 (100%+)
Gabc- Brilliant idea .. thumb nuts to secure the top plate.. anyone make matching red anodized ones?
Raman is offline
Old 10-16-2017, 04:57 PM
  #26
JayL's Avatar
Exotek, red!
ALLOY TWIST NUTS - Exotek Racing
JayL is offline
Old 10-17-2017, 11:03 AM
  #27
sg1
sg1's Avatar
A few things I seen you may want to try....
-remove spacers from rear wing mount or use much shorter (bring wing closer to rear axle)
-remove shim from under steering block (add droop)
-less steering turnbuckle angle (change Akerman)
-add weight under bellcrank (2oz. min.)
-Try batteries inline
-Try raising shock at upper pod plate mount
sg1 is offline
Old 10-17-2017, 11:06 AM
  #28
sg1
sg1's Avatar
gabc...
I posted a pic of my old car on the other thread so we don't clutter this one up... lol
sg1 is offline
Old 10-17-2017, 02:41 PM
  #29
idbdoug's Avatar
Trader Rating: 37 (100%+)
Gab
If your not running a soft kingpin spring a softer kingpin spring might also help
idbdoug
idbdoug is offline
Old 10-18-2017, 04:57 AM
  #30
sg1
sg1's Avatar
idbdoug
I agree, I run Assoc. .018" and have even tried .016" with 30K grease on the kingpins
sg1 is offline
