Old 04-22-2007, 08:11 AM   #301
Default 2.4GHz
i had this problem, receiver got into fail safe after 10mins of run on a buggy. will it help if i install a cap to the receiver??
cash is offline   Reply With Quote
Old 04-22-2007, 04:16 PM   #302
Default LRP Quantum Bullet problem with 2.4ghz
Had a problem with a LRP Bullet speedo getting stuck on full throttle when running 2.4ghz HRS, this is the second LRP speedo I ave had the trouble with.
The strange thing is it runs fine with a novak GTX, I have 2 receivers and they both do the same thing.
I just wondered if anyone has any ideas, I'm running 6 cells and 27t motor, I have tried all support in UK hence I now have 2 receivers and 2 speedos all tech guys stuffed for ideas as its intermitent.
bomber UK is offline   Reply With Quote
Old 04-26-2007, 12:52 PM   #303
Regional Moderator
Darkseid's Avatar
Does anyone know if the R603FS receiver works with the 3PM 2.4G? As far as I could tell, the only difference between that and the R603FF is that the FS has dual antenna(1 internal+ 1 external)
Thanks in advance
TLR 22...Tamiya F104...
Old 04-26-2007, 01:08 PM   #304
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Yes it works....Im using one with my 3PM and I have no issues.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-26-2007, 01:26 PM   #305
Default R603FF/FS difference?
Query,
It sounds like there are 2 styles of receiver out, is this correct? If so, what is the difference between the 2 of them?
Cheers in advance.
CML | TiR | Microtech Racing | Tubz Designz
StuartC is offline   Reply With Quote
Old 04-26-2007, 03:12 PM   #306
Rick Vessell's Avatar
Stuart,
Like Darkseid said, the only difference is that the FS has internal and external antenna and the FF has only the external. No other differences.
Socko
Rick Vessell is offline   Reply With Quote
Old 04-26-2007, 08:05 PM   #307
Kenneth Tan's Avatar
Since there is the FS and FF, which situations repectively are they recommended for?
Kenneth Tan is offline   Reply With Quote
Old 04-26-2007, 08:18 PM   #308
Regional Moderator
Darkseid's Avatar
Thanks. Just wanted to know so I can know all my options while surfing the buy/sell boards.
Old 04-26-2007, 08:23 PM   #309
Regional Moderator
Darkseid's Avatar
They're pretty much both ment for the same situations. According to Futaba, the FS just has less chance of signal drop compared to the FF. And the FS cost $10 more. I guess its just a little more security to go along with 2.4G technology AND failsafe.
I wouldn't buy the FS over the FF just for that, but if I find one used, I wanted to be sure it would work.
***edit*** its the FS that has less chance of signal drop, I had it the other way around originally.
Old 04-26-2007, 10:26 PM   #310
Originally Posted by Darkseid
They're pretty much both ment for the same situations. According to Futaba, the FF just has less chance of signal drop compared to the FS. And the FS cost $10 more. I guess its just a little more security to go along with 2.4G technology AND failsafe.
Strange, FF is sounds better than FS, as it has less chance of signal drop, but FS costs $10 more?
Old 04-26-2007, 11:10 PM   #311
rc-zombies's Avatar
The FS run in HRS high response mode or PPM. has auto detection for the different modes. only works with the 3PK.
I haven't had any problems with signal loss with mine.
Old 04-27-2007, 12:48 AM   #312
Send a message via ICQ to Seano
Just FYI it also works with the futaba 3vc
Seano is offline   Reply With Quote
Old 04-27-2007, 07:18 AM   #313
Zombie,
As Kevin K and I both stated you can use either RX with the 3PM. The FF only has the external antenna, that's the only difference. And yes it also works with the 3VC for you stick drivers. Darkseid has is backwards, the FS has less chance of signal drop since it has both antennae. Either way, you can't go wrong. Both RX work great and the 3PM is a great radio for someone who doesn't want or need a 3PK system.
Just ask Kevin K, he has driven both TXs and I'm sure he is just as happy with the PM as he would be with the PK.
Socko
Old 04-27-2007, 07:21 AM   #314
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
socko do you check your personal stuff like pm or email ?
wallstreet is offline   Reply With Quote
Old 04-27-2007, 07:24 AM   #315
wallstreet's Avatar
Futaba system works flawlessly ... no glitches and no worries of who is on your channel... one of the best investments i have made in rc.
Futaba 2.4Ghz module with two receivers, Futaba servoes dirtyrc R/C Items: For Sale/Trade 34 09-08-2008 09:04 AM
Futaba 3PK 2.4GHz NEW glock19er R/C Items: For Sale/Trade 5 04-07-2008 04:27 PM
Futaba 3PM 2.4ghz nrtv20 R/C Items: Wanted to Buy 0 01-16-2008 12:03 PM
FUTABA 4PK 2.4ghz casye Malaysian R/C Racers 8 11-13-2007 12:42 PM
WTB: 2.4ghz kit for Futaba 3pk nocigar R/C Items: Wanted to Buy 0 07-04-2007 10:20 PM
