Old 04-16-2007, 02:40 PM   #286
Regional Moderator
Darkseid's Avatar
Quick question guys:
Is it safe to assume that Futaba's Fasst 2.4G system is incompatible with Spektrums recievers?
TLR 22...Tamiya F104...
Old 04-16-2007, 02:43 PM   #287
94_snake's Avatar
Correct, they will NOT work with each other. The Fasst module, has to have the fasst receivers.
94_snake is offline   Reply With Quote
Old 04-16-2007, 02:58 PM   #288
Regional Moderator
Darkseid's Avatar
Thats what I figured, but wanted to be sure.
Old 04-16-2007, 08:41 PM   #289
Kenneth Tan's Avatar
Anyone knows what will happen if the FASST receiver antenna is cut or bent? Glitches?
Kenneth Tan is offline   Reply With Quote
Old 04-16-2007, 09:45 PM   #290
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by JonnySocko
Yo,
You got pm foo!
Good thing I wasnt holding my breath....still no ring ring from ya
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 04-16-2007, 09:47 PM   #291
Team EAM
Bending will not hurt it. If it's cut it is possible to get glitches and is best if you get it repaired. I just cut mine to by accident and got to send it in
EA
Contact Us
Old 04-16-2007, 11:18 PM   #292
Mine was bent 90 degrees upon opening the packaging, exactly at the point where the white wire is exposed. I thought it was byebye... Thanks for the info.
Old 04-18-2007, 01:30 PM   #293
GREGORY!'s Avatar
Default futaba
Hi !does anyone know if the megatech-futaba 3pks is the same as the futaba magnum 3pks?if not,who they is the differences?
GREGORY! is offline   Reply With Quote
Old 04-18-2007, 02:16 PM   #294
94_snake's Avatar
I dont know for sure on the 3pks, but on the regular 3pk, the only difference was the color. And the fact that Futaba USA would not service the Megatech, it had to be sent overseas. But I have never had a problem with my Megatech, so that is/has not been an issue. Now since the Magnums are the grey color, I would only assume that they are the same.
Maybe some more insightful people can add more, but that is my thoughts on it anyway.
Old 04-18-2007, 07:19 PM   #295
Regional Moderator
Darkseid's Avatar
Well my 3PM 2.4G should be here in a couple days. I'm switching from a 3PK to this. I'm happy with the feel,(feels better to me than my 3PK), and I'm REALLY happy with the light weight. I'm just hoping that the menus are easy to navigate and user friendly.
Any tips/tricks I need to know about using this radio/receiver?
Old 04-21-2007, 02:43 PM   #296
Originally Posted by Babalu
Thanks for the help!
you think they put it in the manual da
LORD SHADO is offline   Reply With Quote
Old 04-21-2007, 02:45 PM   #297
buttons were changed and some other things
Old 04-21-2007, 02:46 PM   #298
Originally Posted by redsand
I ran my Fasst system yesterday in a 1/8th buggy club race. I wrapped the RX in a ballon and after 30 minutes main, the RX got warm. Is that normal ? I don't really recall RX gets warm when I was running Airtronics.
their a little tiny pc in side . yes it will get warm .
Old 04-21-2007, 02:49 PM   #299
Originally Posted by ercwhtsd
babalu- i run the 3pm fs pro with digital servo s9451, as socko stated if you run in hrs mode you MUST use a digital servo otherwise you will burn it up,glitch or generally have an issue. i ran the stock servo in a tc4 for a week in ppm mode as well before i got the digital.
you can got to tower hobbies and search them, they have a brief spec sheet for the radio listed with each controller and recomennded accessories. the controller i have is tower stock # LXL2P2
jest change the select model name in the 3pk , wont have a problem.
Old 04-22-2007, 01:51 AM   #300
grizzle's Avatar
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Hi, got my 3PM FASST a week ago. So far no problem. It feels smooth to me and no glitching whatsoever, very happy with it.
I bend the antennae tube gradually to enclose it inside the car shell to protect it during crash and rollover . Range is still good. Cheers
Pro4, TA05R, Cyclone TC, 3PK2.4, NGLLRME, TA04R
grizzle is offline   Reply With Quote
Futaba 2.4Ghz module with two receivers, Futaba servoes dirtyrc R/C Items: For Sale/Trade 34 09-08-2008 09:04 AM
Futaba 3PK 2.4GHz NEW glock19er R/C Items: For Sale/Trade 5 04-07-2008 04:27 PM
Futaba 3PM 2.4ghz nrtv20 R/C Items: Wanted to Buy 0 01-16-2008 12:03 PM
FUTABA 4PK 2.4ghz casye Malaysian R/C Racers 8 11-13-2007 12:42 PM
WTB: 2.4ghz kit for Futaba 3pk nocigar R/C Items: Wanted to Buy 0 07-04-2007 10:20 PM
