Old 10-26-2006, 11:11 AM   #181
TFR
TFR's Avatar
Just one question, is the antenna from the 2.4GHz receiver any different than the normal HRS 203HF receiver? The reason I ask is I'm routing the wire under the receiver and directly on top of the carbon chassis, would it cause problems? I had the same set up with my HRS receiver with no problems.
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 10-26-2006, 11:16 AM   #182
rc-zombies's Avatar
TRF.
the 2.4GHz antenna is different from the std HRS receiver antenna that is a single wire.
the 2.4GHz is like a mini coax cable.
Old 10-28-2006, 05:19 AM   #183
I am running the system at The Gate this weekend at the Halloween Classic in both T/C and 1/12th, couldn't be more pleased.
chuck
mackin is offline   Reply With Quote
Old 10-29-2006, 06:22 PM   #184
So will the system work with analog servos? I am fed up with my Spectrum!
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 10-29-2006, 11:10 PM   #185
TFR
TFR's Avatar
The R603FS receiver can work in either PPM or HRS, so analog servos in PPM will work.
One question, what is the last slot on the receiver for? It says RS232C.
Old 10-30-2006, 01:28 AM   #186
rchoudini's Avatar
rs232 is a computer cable connector. maybe its programable!
rchoudini is offline   Reply With Quote
Old 10-30-2006, 09:35 AM   #187
rc-zombies's Avatar
says in the instructions that the RC232 is for factory use only.
but I think it will be user programable in the future.
Old 10-30-2006, 09:42 AM   #188
wazee's Avatar
Ok, not exactly a 2.4Ghz Futaba problem but it has to do with it..(and my Futaba 2.4 system is on the way) ..so i checked my 3pk today and discovered a strange problem:
It seems that the power switch and the display switch are kinda linked.
I can turn my radio on with the power switch AND the display switch on the side and also turn it of with each of them. But when i try to switch off the display while the power is "on" it doenst't work.
Anybody got this problem to?
Not so tragically at all, never turned the display off before, while racing, but its a little bit strange.
wazee is offline   Reply With Quote
Old 10-30-2006, 10:25 AM   #189
rc-zombies's Avatar
no they are not linked... the power switch is the main switch you should be using.. the display switch allows you to make changes in the pits without sending out a signal that may interfere if other cars are running on the track.
Old 10-30-2006, 10:39 AM   #190
wazee's Avatar
should have read the instruction better, on page 8
can't remember that i ever used this function and i probably never will with the 2.4 module, but thanks anyway
Old 10-30-2006, 07:38 PM   #191
Here's the soon to be released 3PK-S 2.4ghz system with integral antenna...
j/k...I took the module apart and rerouted the antenna... If I only the coax cable was another 3-4 inches longer... I could do the mod.
How soon are we talking?
wilsonproperties1.com
Isaac is offline   Reply With Quote
Old 10-30-2006, 11:16 PM   #192
rc-zombies's Avatar
I was just kidding... I took my module apart and repositioned the antenna..
Old 11-05-2006, 08:41 AM   #193
ok my question is the instruction manual says to turn on the transmitter I did that, Green led comes on but then when I turn on my speedo (novak gtx) nothing by the way i'm running touring car (carpet) also I'm assuming that the streeing servo goes into number 1 slot speedo number 2 personal trans number 3 and were do I plug my fan could some one please help.
al jones is offline   Reply With Quote
Old 11-08-2006, 12:21 AM   #194
H I
H I's Avatar
Trader Rating: 18 (100%+)
Have you tried press switch on receiver? you have to keep pressing till green light comes on. For fan you can get double plug for receiver from hobby shop. Try use it on No.2 or 3.
Has anyone tried analog servo with PPM mode? Dose it cook servo or receiver?
H I is offline   Reply With Quote
Old 11-08-2006, 08:15 AM   #195
Send a message via AIM to adamliehr
Futaba 2.4 FASST System Tqed and won Pro 19turn at the 2006 Oval Masters held in Greeneville Tennessee. We had over 125 racers in attendance, and ran all weekend without a single glitch!!!!
THANKS FUTABA!!!!!!!!!!!
adamliehr is offline   Reply With Quote
Futaba 2.4Ghz module with two receivers, Futaba servoes dirtyrc R/C Items: For Sale/Trade 34 09-08-2008 09:04 AM
Futaba 3PK 2.4GHz NEW glock19er R/C Items: For Sale/Trade 5 04-07-2008 04:27 PM
Futaba 3PM 2.4ghz nrtv20 R/C Items: Wanted to Buy 0 01-16-2008 12:03 PM
FUTABA 4PK 2.4ghz casye Malaysian R/C Racers 8 11-13-2007 12:42 PM
WTB: 2.4ghz kit for Futaba 3pk nocigar R/C Items: Wanted to Buy 0 07-04-2007 10:20 PM
