Old 01-30-2006, 01:04 AM   #1
Drewdc90's Avatar
Default Gearing for mod
Hi
I finally got to run my old (still in the packet) D6 yesterday but I'm not if I've got the gearing right as the motor went well the first run but didn't reach full revs the second run. I had a look at the com and it was silver, I'm running XXX octagonal brush and a 24.8 rollout on a 40 metre straight or so.
The timing is advanced 20 degrees which is how it came.
Just wondering what could be the cause of the com over heating.
Thanks, Drew.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 01-30-2006, 01:29 AM   #2
Superkarter's Avatar
turn the timing down and what wind is it?
Superkarter is offline   Reply With Quote
Old 01-30-2006, 02:44 AM   #3
Drewdc90's Avatar
Its an 8 turn double flat wind. Was super fast for one heat. Then just quicker than a 19 turn the next. I thought I'd get 2 runs before it needed a cut.
Old 01-30-2006, 04:07 AM   #4
Jack2's Avatar
24.8mm is a little high in my opinion for a 8 turn on a 40 meter straight (depends what the turn before the straight is like...), I have never had much to do with flat wire stuff but I know they are supposed to be pretty rippy acceleration wise. I'd say go back to 23mm or so and give that a try. Without knowing more detail about the track (layout i.e., technical, flowing, high grip/low grip etc.) itís hard to give any reasonable suggestions.
The comm turning silver is bad, I would look at running some different brushes and springs, timing it differently (depends on what batteries you run) and then play with ESC settings and see if you can get better wear out of that.
To get the most out of starting a thread, list as much DETAIL as you possibly can......
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 01-30-2006, 03:14 PM   #5
Drewdc90's Avatar
The turn before the straight is a 180 degree corner and isvery slow. The track is pretty low grip and is a bit slower than brendale. I'll try turning the timing down to 10 or 15 degrees.
Thanks, Drew.
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
