    Hide Wikipost
Old 10-30-2017, 01:53 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray T4 18
Last edit by: R Dodge
Welcome to the XRAY T4'18 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time. Feel free to add anything you feel is useful to the community!
New for 2018:
Similar to 2017, the T4'18 kit comes available in the U.S. with either a Graphite chassis (Part no. XRA300024), or Aluminum Flex chassis (Part no. XRA300024A) along with all of the great features introduced last year. We recommend the Graphite chassis for starting on asphalt, and the Aluminum Flex for starting on carpet. The big changes for 2018 are much lower center of gravity, courtesy of the Ultra Low Profile (ULP) shocks/towers and narrower weight distribution by shifting the motor in towards the center-line of the car. In moving the motor closer to the center, the topdeck and layshaft bulkheads have been re-designed. Also new this year, the motor mount includes more holes which extend further toward the rear of the car to improve traction. With the new shorter shocks, the 2018 will use the same springs as previous T4 models.
What's NEW at T4 2018? Convert your '17 to '18 specs with these parts:
- NEW chassis plate (3 options to chose from, Graphite, Aluminum, Alum. Flex)
- NEW topdeck
- NEW ULP shocks (4mm shorter than 2017)
- NEW ULP shock towers (4mm shorter than 2017)
- NEW Motor mount (1mm narrower than 2017)
- NEW Motor mount plate
- NEW layshaft bulkheads
- NEW 51mm ECS ES driveshafts
301145 T4'18 CHASSIS 2.2MM GRAPHITE
301199 T4'18 UPPER DECK 2.0MM GRAPHITE
302084 ULP SHOCK TOWER FRONT 3.0MM GRAPHITE
303001-O T4'18 ALU LAYSHAFT BULKHEAD RIGHT - ORANGE
303002-O T4'18 ALU MOTOR MOUNT - ORANGE
303003-O T4'18 ALU MOTOR MOUNT PLATE - ORANGE
303085 ULP SHOCK TOWER REAR 3.0MM GRAPHITE
305221 ECS (ES) DRIVE SHAFT 51MM FOR 2MM PIN - HUDY SPRING STEEL(tm) (1)
305334 ECS ES (EXTRA STRONG) DRIVE SHAFT 51MM - HUDY SPRING STEEL(tm) - SET
308043-O ULP ALU SHOCK ADJUSTABLE NUT - ORANGE (2)
308308-O ULP ALU SHOCK ABSORBER-SET - ORANGE (2)
308324 ULP ALU SHOCK BODY (2)
308334 ULP COMPOSITE SHOCK PARTS
308354-O ULP ALU SHOCK CAP-NUT WITH VENT HOLE - ORANGE (2)
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Mastering the Sanwa M12S: Utilizing Exponential and RMode
How to mount weight on your chassis Part2
Mastering the Sanwa M12S: Utilizing TH-Hold
ULP Shock:
Building the new ULP Shock w/ Zero Rebound by Dominic Quek
Team driver Tim Wahl posted some very useful build tips for the T4'16 on Facebook as he worked through building a new kit. These tips will still apply on the current model.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
Center Brace:
The manual indicates using a 2mm shim under the center brace when attaching to the chassis plate. The gap is actually 3mm, so a 3mm shim should be used here.
Tuning Note:
On Carpet we have found that adding screws or doubling up the graphite brace will make the car react quicker to steering input, & change direction faster. Raising the graphite brace off of the aluminum bulkheads by placing a shim under it on the front and rear holes will reduce response. Using the tie-rod will reduce initial response to input, but will generate more in-corner traction or 'side-bite'. Using no brace will generate even more of this 'side-bite' but all of this is at the expense of corner speed. Best to use the tie-rod or no brace only in low-traction conditions. Additionally, the center brace increases forward traction, so removing it will potentially increase wheel-spin out of low speed corners.
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
ARS Tuning courtesy of Ed (TryHard):
If you set the ARS up with no shims under either inside or outside ball positions, it actually adds toe-in under compression, at around 1° at 5.2mm ride height (how much it adds depends how much the car compresses, obviously )
Adding shims reduces the amount added (1mm under one of the links gives about 0.5°), until the link has 2mm worth of shims (1mm either side, or 2mm on one side) makes the ARS neutral. Adding more shims then turns it into reducing toe in under compression.
Whilst that might sound a bit backwards, it's actually not quite as simple as it sounds. By having the links to add toe, you gain forward traction. Also consider as the car rolls, the inside wheel is in negative compression, and the outside in compression. So the inside is toe-ing out, and the outside toe-ing in, so the whole rear is then 'steering' in the direction of the turn. Obviously the inside wheel has a lot less influence than the outside as it's far less loaded, but the effect is still there.
Optional & Tuning Parts to consider:
XRA301146 T4'18 ALU CHASSIS 2.0MM - SWISS 7075 T6 **For high traction**
XRA301147 T4'18 ALU FLEX CHASSIS 2.0MM - SWISS 7075 T6 **For very high traction**
XRA301169 T4'18 UPPER DECK 1.6MM GRAPHITE
XRA302254 Composite Steering Block - Graphite
XRA302334 Aluminum C-Hub Block - Caster
0° - Orange **Only for ARS**
XRA302383 Composite C-Hub Right – 4
° - Graphite (ECS) **Not recommended for high traction**
XRA302384 Composite C-Hub Left – 4
XRA302711 Brass Front Lower 1-Piece Suspension Holder - Front - FF
XRA302803 1.3mm Front Anti-Roll Bar
XRA303360 Composite Upright 0° Outboard Toe-In - Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel **Highly recommend**
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA305352 Aluminum Wheel Hub - Offset
“+0.75mm” - Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308029 ULP ALU PROGRESSIVE SHOCK SYSTEM - SET (2) **Only for asphalt**
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Recent Setups:
7-Oct - Alexander Hagberg - IIC - High Traction Carpet - Mod Q2, P2
7-Oct - Craig Xavier - IIC - High Traction Carpet - SuperStock Q5, P5
Print Wikipost
Like Tree158Likes
Old 12-13-2017, 03:06 PM   #481
RobS's Avatar
Originally Posted by mracer1 View Post
Current best price for the T4 18?
tia
Mike ;>)
Because we are Canadian... LOL
mracer1 likes this.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 12-13-2017, 03:36 PM   #482
SlowGuySam's Avatar
Thanks for all the info. I figured it was wishful thinking. Guess I will just have to run my ‘13 till the deck finally breaks lol.
SlowGuySam is offline   Reply With Quote
Old 12-13-2017, 04:11 PM   #483
erchn's Avatar
Honestly, Bezerk is a great choice.
If you really want something local, you might reach out to Reflex Racing, Cristian almost definitely has drawings and capability to cut a t4 '13 chassis still.
Ethan
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 12-13-2017, 04:33 PM   #484
EA should have you ve covered for your needs.https://www.facebook.com/APEXRaceway/
freebird is offline   Reply With Quote
Old 12-17-2017, 02:06 PM   #485
Can someone pls tell me the maximum spring length for the ulp shocks?
Gero is offline   Reply With Quote
Old 12-17-2017, 04:25 PM   #486
Xray stock springs (since SLP shocks) are 20mm
These don’t leave much room on the ULP shocks, maybe 2-3mm at most with “typical” ride height. You’ll note Xray changed the spring collar to be 1-2mm thinner than the old one - that’s how little we are playing with here.
Look for 20mm springs is the answer.
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 12-17-2017, 10:58 PM   #487
Thx
Old 12-19-2017, 05:34 PM   #488
Skiddins's Avatar
Can someone please tell me the difference in weight of the T4'18 alu flex chassis (301147) and the std kit chassis.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-19-2017, 07:16 PM   #489
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I think its around 15g D.
"If you think you can, or can't, you're right"-Ford
"[Driving] Genius is 1% inspiration, and 99% perspiration"-Edison
◢◤Xray◢◤Hudy◢◤RC America◢◤Hobbywing◢◤R1 Wurks◢◤
◢◤Pro-One◢◤Protoform◢◤AVID R/C◢◤
Old 12-19-2017, 10:22 PM   #490
DirkW's Avatar
T4'18 Alu Flex is (according to my scale) ~93.45g - don't have the standard one.
Dirk
My On-Road cars: Xray T4'18 | Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | ((Xray X1'18)) | Xray X10'16 | Yokomo SD SSG | ((VIP-Performance Vorlon/VTE))
My Off-Road cars: Yokomo YZ-2 DTM | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory>>>((?Yokomo YZ-4SF?)) | Kyosho Ultima SC6 | Tekno SCT410.3 | ((Xray XT2'18))
DirkW is offline   Reply With Quote
Old 12-20-2017, 02:34 AM   #491
Skiddins's Avatar
Thanks guys
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 12-30-2017, 06:30 PM   #492
Could anyone comment on the xenon white belts vs xray belts?
Sean B. is offline   Reply With Quote
Old 12-30-2017, 09:17 PM   #493
They're made by the same manufacturee just rebranded and probably cheaper since its not under the x ray brand.
Sean B. likes this.
BD1541 is offline   Reply With Quote
Old 01-01-2018, 09:26 AM   #494
Are there any foam tire setups out there, or what would be the first thing to change from a rubber tire setup? For carpet.
Old 01-01-2018, 10:41 AM   #495
masterhit's Avatar
Trader Rating: 15 (100%+)
If you're going to race where I think you're going to race.... Any of the black carpet setups work really well as a start. They will get you 95% there.
Mike
masterhit is offline   Reply With Quote
Xray M18 Pro LiPo Edition mdowney Micro and Mini Scales 28 07-13-2017 02:23 PM
The New Xray T4 '13 jorgesimes Electric On-Road 5620 01-31-2016 08:51 AM
Xray XB9 13 vs Losi 8IGHT 3.0 themis Nitro Off-Road 54 07-17-2013 10:32 AM
XRAY T3 vs. TC6.1 vs. S411 - Which one and why? Onetrade Electric On-Road 40 05-26-2012 11:32 AM
HUGE 1/8 Buggy/Truggy Sale! (Xray, Losi, Mugen) K_B R/C Items: For Sale/Trade 47 04-16-2010 02:05 PM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
FunStuff, IJsbier
