Foams for 2006 Snowbirds >
Old 01-28-2006, 09:11 AM
TL_XXX-S_racer's Avatar
Default Foams for 2006 Snowbirds
Hey guys, I just wanted to know what foams you guys are running for 1/10th scale on-road. I was going to run the TRC Cyan and Magenta with the black spoked rims. Does anyone know where I can buy them or if they're still being sold. If not what else is there for me to use?
Thanks,
Chris
TL_XXX-S_racer is offline
Old 01-28-2006, 09:47 AM
BritRacer's Avatar
I think a good start for stock/19t would be the jaco 2 stage wraps.
If you are running mod, I would suggest taking some jaco dbl pink / dbl pink Org also.
Take plenty! Practice, club race, quals, mains, thats a lot of tires
BritRacer is offline
Old 01-28-2006, 10:37 AM
Can you give me the link to TRC and the JACO site? Im running stock.
Ya im probably going to bring more than 4 sets, but I can always get more there if i need too.
Thanks,
Chris
Old 01-28-2006, 11:24 AM
Andrew Gray's Avatar
www.jacoracing.net
Andrew Gray is offline
Old 01-28-2006, 08:48 PM
Rob Phillips's Avatar
check out speedtechrc.com or kthobbies.com for Jacos or Parmas. They have very good prices and excellent customer service to boot.
Rob Phillips is offline
Old 01-28-2006, 11:53 PM
jbenthobbies's Avatar
Default tires for snowbirds
you might want to give BSR tires a try. They have a true durometer. Try double pink in the rear and double pink with orange in the front.
jbenthobbies is offline
Old 01-29-2006, 02:39 PM
Trader Rating: 202 (100%+)
I believe BSR is Jaco wheels and rubber.
How does the TRC foams compare to Jaco/BSR with wheel durability?
dodgeguy is offline
Old 01-29-2006, 02:44 PM
Korey Harbke's Avatar
BSR uses a different foam I think.... They do use Jaco wheels though. I feel jaco rims are better. They are slightly larger in diameter, and stiffer. The foam on the TRC runs a bit soft.... not really good for super high traction conditions in my opinion.
-Korey
Korey Harbke is offline
Old 01-29-2006, 09:18 PM
Super Moderator
Trader Rating: 20 (100%+)
Wow I actually like Parma's better than all the rest right now. They just seem the most consistant. Wraps will be good for a run then bad then good again.
Bob Barry is offline
