Old 01-27-2006, 06:08 PM   #1
semore's Avatar
Default Questions on power cap for Rx/servo
Hey all- I have a question reguarding the power cap. Does it really matter what size of cap you use? I have a power cap fromm my old cyclone and want to use it with my spektrum Rx and digital steering servo. The Rx stops because of the built in fail safe. I have already soldered the power cap to a conector soo I could plug in the battery input. Do you think this would OK I dont want to smokey my Rx oor servo.
Thanks Semore
semore is offline   Reply With Quote
Old 01-27-2006, 06:13 PM   #2
Talking
just go buy one from spektrum, they plug striaght into your receiver $7
XingXing is offline   Reply With Quote
Old 01-27-2006, 06:25 PM   #3
semore's Avatar
I will but want to race tomoro with my son and non of the LHS have them and iit would have to ordered.
Old 01-27-2006, 06:27 PM   #4
ok. the spektrum cap is a 10v 4700uF Cap. any cap with spec of higher than 5.5v will do.
just connect a receiver plug to it and plug it to your AUX or Batt Channel. If no spare channel you need a splitter.
Old 01-27-2006, 06:39 PM   #5
semore's Avatar
Thanks thats what I was looking for.
Old 01-27-2006, 09:34 PM   #6
BATT_MAN's Avatar
You want to make sure that you use a LOW IMPEDANCE electrolytic capacitor. Not all capacitors have the same properties, and the impedance is very important for propper operation. You can go up to 8200uf without having any problems.
Most of the capacitors sold at places like Radio Shack are of the normal type. You need something like a PANASONIC FC SERIES.
Most capacitors are rated at 85'C and you will do better with a 105'C cap. THE FC SERIES is the right capacitor for thos application. Other companies make LOW IMPEDANCE caps, but the easiest to get is the PAN FC.
If you need a source for this capacitors you can PM me.
BTW, WATCH THE POLARITY!
Hope this will help you.
BATT_MAN is offline   Reply With Quote
Old 01-28-2006, 06:20 AM   #7
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
The Cyclone caps are LOW ESR(as BATT_MAN suggest), so yes, they will work fine.
That is what I used on mine.
Tres is offline   Reply With Quote
Old 01-30-2006, 01:32 AM   #8
BATT_MAN's Avatar
I did not read your question carefully.
Tres is correct, the CYCLONE caps are the right type.
As a fact, they are either the PANASONIC that I suggested or an alternate brand.
servo questions rgrg2 Radio and Electronics 3 08-10-2008 05:22 AM
Power caps concern and questions akuhon Electric On-Road 10 02-16-2007 12:13 AM
Power supply problem and questions ken39 Singapore R/C Racers 6 03-08-2006 02:56 AM
Power Supply questions Fred Perkins Chat Lounge 2 05-05-2004 01:22 PM
