Old 01-26-2006, 07:52 PM   #1
Default LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200
Anyone know what's the best setting for IB3600, 3800 or 4200 on LRP Pulsar 1 charger.
Please share with me....
rcmnx is offline   Reply With Quote
Old 01-26-2006, 11:02 PM   #2
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
6-7 amps, 10mv cutoff...
killer89 is offline   Reply With Quote
Old 01-26-2006, 11:04 PM   #3
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
my pulsar 2 is set at 6amps 55 or 50mv cut off
Roberto Falcon is offline   Reply With Quote
Old 01-26-2006, 11:22 PM   #4
killer89's Avatar
WOW... Thats a little high for the cutoff no? Are you talking about IB batts? of NiCDs? what do the peak temp at?
Old 01-26-2006, 11:23 PM   #5
Old 01-26-2006, 11:23 PM   #6
Thanks for the info.
with 6 amp and 50mv cut off will it be too hot to touch for stickpack ?
I think 6-7 amp with 10mv is safer...
SMC battery recommend their IB3800 match with 6 amp 20-30mv but I don;t know which charger they (SMC) refer to.
What's the final maH read in the display for IB3600, 3800 or 4200 ?
Old 01-26-2006, 11:27 PM   #7
killer89's Avatar
my 3800s take 4300mah
Old 01-26-2006, 11:30 PM   #8
I use IB3800's.. and they just get warm
Old 01-26-2006, 11:36 PM   #9
Thanks...
I only charge the stickpack... standard cell.
No match side-by-side...
Will try it...
Old 01-27-2006, 12:14 AM   #10
Trader Rating: 39 (100%+)
I'm using the Competition 2, but for my 3800's, I set my cut off between 30-35mv right now. The ambient temp is 50-60 degrees at the track. I will set it lower if the ambient temps are warmer or if my batteries peak above 125 degrees.
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 01-27-2006, 10:09 AM   #11
killer89's Avatar
ambient temp for me is about 60-70 at my track...
Old 01-27-2006, 10:37 AM   #12
Originally Posted by ridgewaybodies
.... my batteries peak above 125 degrees.
HOw do you know the temperature of your batteries ? Does the Pul Comp 2 comes with the temp probe ? or do you use temp gun ?
Old 01-27-2006, 05:05 PM   #13
jw92656's Avatar
No the LRP Pulsar2 does not come with a temp guage. I just picked up a DuraTrak one for $24.00. Check the temp on each cell, they will have different temps, and adjust your Delta Peak accordingly to your hottest cell. To lower the temp, lower the delta peak. To raise it, raise the delta peak mV.
jw92656 is offline   Reply With Quote
Pulsar 2, Battery Dr., 4200/3800 Batteries dbmartin R/C Items: For Sale/Trade 4 01-28-2008 08:28 PM
3600, 3800, or 4200 4 cell saddle pack MrZero R/C Items: Wanted to Buy 4 12-03-2007 10:32 PM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 12:05 PM
Intellect 3600/3800 Discharging Methods ? jace Australian Racing 2 08-12-2005 10:52 AM
What is the current demand for Intellect 3600-3800 cells? woody1 Electric On-Road 15 05-10-2005 03:33 AM
