HPI Racing Ken Block 2015 Ford Fiesta ST RX43 WR8 Flux
Good Day,
I'm about to buy this car. I am coming from Heli's and Drones. I'd like to know from owners of the same car. What are the immediate upgrades you think I should go with. If possible if you could provide links to the parts that would also be of great help.
I've read items like the steering system and servo, perhaps even the ESC.
Thanks in advance.
Thanks in advance.
What's the part number for that model? HPI discontinued a bunch of the Ken Block WR8 awhile back. Just want to make sure it's not discontinued because parts may be hard to get for it down the road.
Not really related but I have a 2016 Fiesta ST (the real one). Amazing little cars.
eBay has been best source for parts for it.
I've got 2 of them. Solid vehicle overall both of mine are mostly still stock. While I haven't changed servo yet, I've read of a number of them that have. And sounds like makes big improvement.
The only real issue I've had with it is the stock ESC. Gone through 3, 4th is headed that way.
Its the current model being sold on Towerhobbies. I bought it last night, was too impatient.
Its a great car. Just make sure to get extra set of tires cause they wear pretty fast, say 10 2s packs and the foam is showing. On 3s maybe half that. That is strictly parking lot running.
The steering servo is slow and weak. It works fine but if you race any other rc's you will want to upgrade it. The Protek 100ss from Amain works well but the lead is a little short so you should get a short servo extension right away. You will also want to switch to the heavier servo saver insert that comes with the car.
Will eventually need the HD diff,center diff and gear shaft cups and extra center drive shafts. If you run on dirt they will last longer.
I am currently running Panther rear buggy slicks in soft compound with aka foams in them on stock wheels. I had to trim the inside ribs off the foams to get the right tire profile but they seem to be wearing better than the stock tires. Only have 8 2s packs on them but they still look good. Probably won't get to run it again until spring to see how long they last.
Thanks, will definitely look. Where did you get the cups and drive shafts from? You have a link?
Cool. Well i'll hopefully get my car in the first week of the new year. After which ill get familiar with it. I'd like to replace most of the plastic parts with metal eventually.
Other then the esc failures. Front bumper and hub carriers have been most common break. Hubs have been both stock and aluminum.
After coveting one of these for years, I finally picked one up last week. I sold all of my 2WD buggies, 4WD buggies and short course trucks so I'm using the WR8 to replace 6 vehicles. It seems perfect for the parking garage, dirt roads, snow-covered roads and gravel-filled parking lots that I run in.
For those people that have burned through ESCs, was that running 3S or 2S? I plan to stay 2S, but you never know....
I have a tendency to upgrade my cars as I go. This is the one car I haven't touched except for adjusting the shocks and changing the wheels for different driving surfaces. I have a few euro spec models "digital zebra" which are hard to get in the US so I ordered a few replacement bodies for the shelf when not driving.
Hard car to beat for all around fun.
