Like Tree323Likes
Tamiya M-07 Concept
Old 08-10-2019, 10:50 PM
  #886
Originally Posted by damang999 View Post
I have tried lots of different diff oils and for me 100k to 300k works for asphalt . Even a locked diff works well . I wouldnt go under 100k
Snap oversteer can be cause by lots of things.
A bit more info on setup tires and track type is needed to understand whats going on
i run on carpet. Setup is Per manual. And Iíve tried different tires... tamiya c, tamiya sgrip and now on shimitzu mediums. Droop is 2mm. Same behavior on different tire types. Iím going to try 1m oil and see what happens. It sounds like 30k is way to light. Iím also dropping the punch on esc to about half the value.This should help but I still think itís not setup right.
rippen likes this.
ebohon is offline
Old 08-10-2019, 10:58 PM
  #887
antlockyer's Avatar
I run 1million
ebohon likes this.
antlockyer is offline
Old 08-11-2019, 09:13 AM
  #888
Default Front anti roll bar rod end
Hi, i have the 3 racing anti roll bar kit for the m07 that fits fine on the rear. But for the front the rod ends don't fit on the wishbones as they are too large. Anyone recommend a part number for suitable sized rod ends to fit the front wishbones?
thanks
Timbo1 is offline
Old 08-11-2019, 11:20 AM
  #889
CL
CL's Avatar
Trader Rating: 34 (100%+)
thanks
https://www.tqrcracing.com/shop/prod....asp?p_id=1468
CL is online now
Old 08-12-2019, 05:37 AM
  #890
thanks!
Timbo1 is offline
Old 08-12-2019, 08:42 AM
  #891
eR1c's Avatar
Wow you guys are running some tight diff's, I've found 75k on asphalt to be the best for me.. (I mix 50k and 100k. Too tight and my rear wants to swing out.
eR1c is offline
Old 08-12-2019, 12:18 PM
  #892
Haha same...running 30k here and she runs like a touring car.
rippen and eR1c like this.
Carnage9270 is offline
Old 08-13-2019, 02:36 AM
  #893
20-30K diff oil is what I found to be really good on black EOS carpet, anything higher then that does make the rear of the car lose
rippen is offline
Old 08-13-2019, 04:12 PM
  #894
R/C Tech Elite Member
monkeyracing's Avatar
Weíve been running 1M to 2M on black carpet. It still allows a little diff action, without the potential spool related wobbles.
if the car is squirrelly on throttle, thereís a simple method I was taught that fixes it 90% of the time.
with you car on a level surface and settled down, lift the front of the car by the center of the bumper slowly. Look to see if one heel lifts up earlier than the other. If so, increase the preload (tighten up) the spring preload on the opposite corner at the rear, just a little. Repeat process for all four corners. It usually helps a car that pulls to one side or this other.
rippen and ebohon like this.
monkeyracing is offline
Old 08-13-2019, 04:35 PM
  #895
gigaplex's Avatar
Make sure your droop is symmetrical left to right before trying this trick
ebohon and dman18t like this.
gigaplex is offline
Old 08-13-2019, 10:34 PM
  #896
what would cause the rear to loose traction if the front diff is to tight? I donít understand the cause and effect.
ebohon is offline
Old 08-14-2019, 12:46 AM
  #897
gigaplex's Avatar
If the front diff is loose, it can diff out in the corners, reducing speed. A tighter diff can increase corner speed, which puts greater stress on the rear tyres.
rippen likes this.
gigaplex is offline
Old 08-14-2019, 07:38 AM
  #898
hello,
thank's for the tire advise ! Mgrip Front /Sgrip rear work's fine on my asphalt track.
I start with the box set-up but after 2 test session, i change shock oil (450 all over), rear spring (hard TC tamiya spring/white), less rear TOE and 6į front suspension mount.
motor : trinity 21.5t monster with 24 pinion, 15į boost and turbo timing. But i will purchase a 17.5t, 21.5t have lot of torque but not so good end speed.
just a question, i never run a FWD, but front tire seems to die very quickly, after 8 session of 5 min....there are just slick now....is it normal ?
i buy some hard pit shimizu to test !
thank's !
rippen likes this.
albator42 is offline
Old 08-14-2019, 08:12 AM
  #899
Originally Posted by albator42 View Post
hello,
thank's !
Fast front tire wear is fairly normal on the front drive cars.
V8 Rumble is offline
Old 08-14-2019, 01:03 PM
  #900
OSherman's Avatar
Whats the status on the YeahRacing-M07 conversion?
WANT!!
OSherman is offline
