Tamiya M-07 Concept
#166
My rear toe in is half of yours. I think less helps with corner speed. Running on
black CRC carpet. No trail brake and not using any brake. Lift and turn.
#167
So, here's my experience with building the M07 Concept.
First off, the amount of fiber injected parts is amazing.
The car does not come with a motor, esc, body, or tires.
To complete the car, you'll need a 2.5mm drill bit, locktite, the usual phillips screwdriver, a set of tires, a body (medium or long), and radio gear. The car comes with oil for the shocks, and oil for the diff.
Of important note, the car comes with some interesting components:
* CVDs
* Metal Motor plate
* Bearings
* Oil filled diff
* Oil filled shocks
* Aluminum rear axles
* Heavy duty servo saver
* Metal steering posts
* Bearing supported steering bellcrank
* Not one screw pin!
The overall design has some really high, high points. All of the suspension components are symmetrical, and the same left to right. A set of spares for this car is half the parts you'd need for a M05.
The suspension hinge pins are of the modern touring car style. That is the outer pivot pins are retained in the hub carriers, providing very little slop. And the inner pivots are retained in cups.
While we're on the subject of swingarms, they all have droop screws.
The car assembles quickly, and logically. Due to design choices that were made for ease of maintenance, assembly order matters a lot less. The M05 is a jigsaw that goes together in one way. There are lots of little access holes you wouldn't expect, to allow for individual components to be easily removed without having to tear apart the chassis.
Most of the car uses the same screws. This A1 screw, while the M05 used a bunch of different screws for assembly. None of the screws are self tapping either. They're slightly harder to start in the plastic, but feel more solid once things are cinched down.
The car comes with adjustable control links on all of the normal places. ... My fingers still hurt from assembling those.
Speaking of adjustment, the car has adjustable rear toe, without needing to swap carriers.
Suffice it to say, i'm very impressed with this kit.
* CVDs
* Metal Motor plate
* Bearings
* Oil filled diff
* Oil filled shocks
#168
I'm really glad to hear there are no self-tapping screws. Those don't belong in RC - ever.
Do you put Chapstick on the threads? That acts as lube and typically makes it easier to screw the ends on the links.
I'm glad to hear it's a great kit though since this will be my first M chassis.
#171
I think you have to drill out the grub screw holes in the bottom of each hub. These allow you to use a screw to retain the outer hinge pin.
#172
#176
What pinion would you guys recommend for a 27T silver can and possibly a 24T Torque Tuned? I'm keeping it tame to run with my friends and their M's that have similar motors.
I also need to get some good tires for parking lot racing so there may or may not be some pebbles. I'd happily listen to those suggestions as well.
Thanks!
Thanks!
#177
Thanks!
Thanks!
What size track?
#178
#180
