Old 03-03-2006, 07:57 AM   #31
XrayFK's Avatar
Originally Posted by Bikerbob
Ok, got it working!!
The 10 ohm 10watt was not enough.. a 30 OHM 10 Watt was good.
Now I have just one last problem. If I hook it up to a charger that changes power quickly then it shuts off. I know this is some kind of protection built into the ps, is there a work around it??
I dont have the grey power good hooked up btw.. did not need it.
James
That's a normal thing with computer power supplies, because they have an overload protection. It should be fine if the charger is plugged in first, then you switch on the power supply. There are ways around it, but I'm still working on a "safer" way to do it. My own power supply can handle a spike of about 5A.
XrayFK is offline   Reply With Quote
Old 03-03-2006, 08:24 AM   #32
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
yeah.. that sounds about right.. was hoping a way around it. One of the chargers I am using is a Duratrax Intellipeak Digital.. and if I set the charge at 6.5 amp, it trips it right away. If I start it low, and manually turn it up.. no problem.
I converted an old AT supply (10amp on 12v) it has not spike protection. Was hoping to use the one (20amp on 12v) to power everything, but I guess not.. Oh well.
James
Bikerbob is offline   Reply With Quote
Old 03-03-2006, 09:11 AM   #33
I have two PSU's made up, and neither trips if I connect/disconnect aything, only time I hade a shut down is when I accidentaly shorted the +12v to ground.
DA_cookie_monst is offline   Reply With Quote
FS: Duratrax ICE Charger, Great Planes Triton Charger, & MRC Power Supply wrxnfx R/C Items: For Sale/Trade 15 08-20-2008 11:33 AM
Computer power supply used for charger power supply? 66Racer Radio and Electronics 7 05-25-2008 12:52 AM
Novak Millenium Pro charger ans N- Power power supply RobertF R/C Items: For Sale/Trade 11 11-27-2005 08:59 PM
Converting Computer Power Supply. Who got it to work? Who didnt? Calvin Ng Electric On-Road 47 02-20-2005 08:17 PM
Converting Computer Power Supply. Resistors Q's Calvin Ng Electric On-Road 12 02-19-2005 08:47 PM
