Advice on 1:10/1:12 aero bodies for speed runs.
Hi,
As the title suggests. I need a new body. I have a 1:10 mini (bsr m rage). However I'm running normal 1:10 size wheels (62mm) 26mm wide.
I'm preparing a functional under tray, splitter and diffuser so to be worth it I want a decent body.
I have seen 1:12 scale pan card bodies, but I don't know if these will fit, especially with 62mm wheels.
The overall dimensions of the car is 210mm wheelbase,. 170mm track. Chassis with splitter and diffuser will be about 360mm, although the body could be 60mm shorter than this without a problem.
Any advice would be great.
Cheers
JJ
Cheers
JJ
I don't have any experience with this bout wouldn't a pan car body be pretty "draggy" because of all the down force they generate?
Cheers,
Jim
Cheers,
Jim
experiment look at the Porsche 962 looking body from RJ Speed. I got one off eBay for cheap, its the old Bolink Co I think any way gotta start somewhere. You need downforce if you want traction
Im running 200mm width and about 185 wheelbase
NEW RJ Speed 1/10 962 Style GTP Body 200mm 1052 | eBay
I think I may have to go with a 190mm width body to accommodate the full size 1:10 wheels and deal with the extra 10mm width overhang. The length isn't an issue as I may leave rear wheels enclosed..
Still struggling to find a good option. The actual pan card bodies use much smaller front wheels so I don't think they will clear. I did find an rs4 bltiz. 1:10 mini for bsr m rage. I may have to go with this and hope the large wheels fit.
What are people's thoughts on the over hang of a 190mm body on a 170mm chassis. I could get 6mm offset 36mm wide wheels which would take up most of that, but would screw up cars handling I fear..
Yes and no. The pan cars will have much cleaner air flow so will be more efficient than a lot of the other rc bodies. However the large rear wing will generate more down force than needed so will need cutting back a bit so as to not cause too much drag. A lot of the 'wings' on rc bodies are not accurate aerofoils they are just scoops so they don't create down force efficiently. I'll be using a proper low pressure undertray and diffuser to generate down force so mostly I need a clean compact body.
If you can find one of these - LZ Mini Touring Car Lexan Body Shell ( For 1/10 Mini) [SPR007-LZ] - $15.20 : Spec-R, The Professional Accessories for R/C minus or a very trimmed wing could do. But a full 190mm touring car body on an m-chassis car would be very odd.
190mm width TC car is expecting a wheel base of about 255mm
M-chassis 170mm width on the M-rage is looking for a wheel base of 210mm. You're not just dealing with the width but also the length.
As I had said previously, you're very stuck for bodies with the m-chassis cars.
The link is helpful. I will try to source one of these.
Thanks again. We
I do find it interesting that more research has not been done on RC car wings, I fly RC gliders competitively and some really smart people have done a huge amount of work to find airfoils that produce the greatest amount of lift with the least amount of drag.
Cheers,
Jim
For sure, as in any scale motorsport it is a balance. Obviously the more down force you have the more drag it will generate, now you just have to find that happy medium.
Cheers,
Jim
Cheers,
Jim
Ground effect probably doesn't scale enough to make it worth while and if you're going to also consider the scale of the bumps in the road, the road surface is probably a little too bumpy to rely on it
There's a thread that's looked at some funky aero here somewhere but can't find it at the moment
Given you're looking at pushing the boundaries, how about home brewing a body for your car? That would be really interesting to see!
