Old 11-22-2002, 11:54 PM   #1
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Default Which Tire Inserts To Use?
I am just curious if it is better to use a firm insert instead of a soft or medium to help keep the tire from changing shape under acceleration and cornering? I have been using sorex tires with sorex medium b inserts for a few months racing stock and have had good luck. I have noticed though that after assembling them that they do have a bit of space in between the tire and insert. I will be getting some new tires here soon and was going to try a med A insert which is Sorex's thick insert unless it will cause problems?
Also, I am fairly new to Sedan, how long do these slicks last racing stock/mod?
Any info would be appreciated.
Blake.
Blakesrc is offline   Reply With Quote
Old 11-23-2002, 01:45 AM   #2
-CriMinaL- |RC's Avatar
Send a message via AIM to -CriMinaL- |RC Send a message via Yahoo to -CriMinaL- |RC
Blake ..
i think you meant 1/10th or 'two door' not sedans.
the difference is more air gap = more traction (supposedly)
the tires do change shape to a certain degree but unless they are shitty compund then it shouldnt affect them long term.
The life span depends on how you drive , track surface, class etc.
running stock i got about 10 runs b4 they started wearing down
and feathering. i havent run rubbers with mod yet so i cant
honestly tell you but i would imagine about 5-8 r5 minute races.
-CriMinaL- |RC is offline   Reply With Quote
Old 11-23-2002, 02:16 AM   #3
It all depends on how much traction the track surface has. The more traction the stiffer the insert. The less traction the softer the insert.
I feel they are the best tires, wheels, and inserts on the market today.
The air gap will help with how cool the tire runs and also with the amount of traction the tire will give. More of an air gap will give more traction because the tire will not overheat as fast when you push the car over the limit.
It shouldn't cause any problems. I run all of the inserts and they all work excellent.
These slicks should last you about 1-6 months if not longer. I race every week and I can go on a set of tires for quite a while. It all depends on how you set up the car and what conditions you run the tires in. Also depends on what tire/insert you are running.
James Nguyen is offline   Reply With Quote
Old 11-23-2002, 07:17 PM   #4
popsracer's Avatar
Default Sorex "Air Gap"
Blakesrc;
You can also use HPI 24mm molded inserts. They have slightly less airgap than the standard Sorex insert and they have 5 different firmness ratings (colors).
popsracer is offline   Reply With Quote
Old 02-11-2008, 12:40 AM   #5
mac853's Avatar
Could somebody tell me which inserts have much thickness and soft to fit RP tires?
Best regards
mac853 is offline   Reply With Quote
What tire inserts are which? Marc_05 Australian Racing 7 06-13-2006 04:40 PM
Tire inserts 20%nitro Electric On-Road 1 03-23-2005 09:07 PM
tire inserts hierog Electric On-Road 19 12-21-2003 08:19 AM
Take-Off Tire Inserts?? Doug Gaut Electric On-Road 15 08-04-2002 05:00 PM
Tire Inserts MikeR R/C Items: For Sale/Trade 3 05-08-2002 12:19 PM
