Old 01-23-2006, 07:58 AM   #16
bigair's Avatar
BTW, RC anonymus, I have bearings, and they all feel fine.
Bushings in a TC4?
bigair
bigair is offline   Reply With Quote
Old 01-23-2006, 12:05 PM   #17
toad's Avatar
i have the team kit and the factory team kit tc4 and haven't had the problem with the lightened steel outdrives. the cvd rips out of the plastic ones even if i use a stock motor. they also melt.
todd
toad is offline   Reply With Quote
Old 01-23-2006, 12:31 PM   #18
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Originally Posted by HVFracingwilly
You say you have replace just about everything else in the diff but the outdrives. When i ran my tc4 i did experiance the same problem you have. I think it was the raised portion that captures the diff ring is to tall and when it expandes it binds on the gear try a new set of outdrives and if that doesnt do it carefully sand down the raised area and that should take care of it.
This is exactly it. I used to sand down the retainer edge for the diff rings JUST enough to hold the ring in place. You could actually see on the diff gear where the outdrive had rubbed it. After it gets warm it expands.
Once I sanded, I ran the same rear plastic diff for a year and it was still smooth, and never slipped or tightened up during a run.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 01-23-2006, 06:14 PM   #19
imjonah's Avatar
Default In the manual?
What page in the instruction manual was that on?
Just Joking.
I have an XXX-S, if you were to write down all the information necessary to maintain adjust and be competitive with this car it could easily run another 30 pages of double sided text.
If you think about it the manuals that come with the cars are totally inadequate for anything besides running the car a few times a year in street in front of you house. What is sad is that the companies have the additional information they are just to cheap to publish it.
imjonah is offline   Reply With Quote
Old 01-23-2006, 09:55 PM   #20
Just Joking.
I built a few TC3/TC4 kits in my day, and NONE of them went together correctly without a dremel. I swear I even remember a supplement sheet one time using the words grind and dremel, or something to that effect?
Old 01-29-2006, 04:41 PM   #21
bigair's Avatar
OK, After checking again, I did see a rub mark on the outdrive faces on both sides. Oddly enough, I couldn't see any marks on the Spur.
I filed down the plastic ledge for the diff rings until the "scratch" was gone, then I went a bit further to be sure they didn't rub again.
Tried the tc4 2day at the track. The Plastic rear diff Still got warm and tightened up. So I gave up, bought the steel OD's, and rebuilt using the old thrust bearings, washers, and spring. I had to use new diff rings, but used the old balls and spur. So.... The ONLY thing that was NEW in this rebuild is the rings and steel outdrives.
It now works fine. Nice and smooth like Butta', loose without slip, and never got hot after 3 heats and a Main. I still don't know what went wrong with the plastic diff, but I'll agree that the metal ones just don't do it, for whatever reason. Hmpphhh.....
BTW, The new steel diffs needed to be tweaked to work with the stock bearings cuz the spindle was too big. After chucking it up and sanding it down, we got the bearings to work, but it was a major hassle.
Bigair
Old 01-29-2006, 11:56 PM   #22
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
With the IRS aluminum outdrives, I remember having to use bushings. There was a sheet that came with them that specified bushings. Not sure if that is the case with the steel outdrives or not, I'm guessing no.
Speedo is offline   Reply With Quote
Old 03-30-2006, 10:02 AM   #23
RH Customs's Avatar
Send a message via AIM to RH Customs Send a message via Yahoo to RH Customs
I had the same problem with my TC3, I have no had the problem at all with the aluminum IRS outdrives in my TC4. What you could try doing is putting more grease on the diff rings. That should help, just sounds like there is to much friction and not enough lube.
RH
RH Customs is offline   Reply With Quote
Old 08-10-2006, 07:17 AM   #24
spidude's Avatar
My problem is quite the opposite... my lighten steel diffs keep loosening and mass slippage occurs. Any suggestions?
spidude is offline   Reply With Quote
Old 08-10-2006, 08:01 AM   #25
Send a message via Yahoo to apexraceway
change the T-nut assembly
apexraceway is offline   Reply With Quote
Gearing Tight? Drift_Buggy Electric On-Road 3 05-28-2008 02:20 PM
Associated t4 diff won't stay tight! TechWun Electric Off-Road 14 07-19-2007 04:38 PM
Tight or loose TC4 DIFF NUCRPTRACER Oval, Larger Scales and More 1 02-12-2007 11:08 PM
tight xxx-s Electric On-Road 6 12-28-2006 12:40 AM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 11:11 PM
