How the HELL do I get these FTC3 dogbones together
Got a factory tem tc3 and the dog bonesare kicking my ace, any special techniques, if not remember, I AM A NEWDICK!!!, thanks in advance. MIKEY check the sig
I'm not sure how you could be having problems with them, if you could describe in more detail what you are having trouble with maybe I could help you. The only thing I can think of is only one side of the cylender that you thread the set screw into is threaded, so you need to pay attention that you are threading into the right side.
Good Luck
Good Luck
Did you try with a toothpick?? It could work for ya
good luck
good luck
