Team Associated 12R6
#63
I use it on my RSD car. Just had to cut the wings off to use my tweak plate.
The other option is to get the Pivot, Side links(has pivot plastic insert), R6 tweak plate and short damper tubes. Easy way to convert a 5.2 to transverse battery.
#64
Yes it does. It fits all cars that used the old associated pivot.
#65
#67
You might struggle with Xenon balls, as they are for a 1/8 pin, the R6 uses 3mm pins.
#71
Aaron, yes, I believe the Xray balls should fit. I don't have an issue with the bottom balls tbh, just the top.
Which Roche balls are you referring to?? As their car used Xenon parts, so 1/8 pin.
#74
Chassis Balancing Guide for RC12R6
