Team Associated 12R6 >
Like Tree127Likes
Old 07-26-2017, 07:46 AM
  #46
Anyone else have one built up yet? Hopefully getting mine in a week or 2
fasteddie48 is offline
Old 08-06-2017, 09:26 PM
  #47
Has anyone that's built this car had an issue balancing the pod? I built one and I have to shim the motor over 5mm to get it balanced and doing that doesn't allow enough rotor shaft for a pinion. I am running a tsr motor if that matters
chad508 is offline
Old 08-06-2017, 11:13 PM
  #48
silden's Avatar
I talked to several top drivers at our club and they said that it isn't necessary to balance the pod, because the pod isn't moving. You have to balance the chassis without the pod.
Edwin Pibal and aracefan like this.
silden is offline
Old 08-07-2017, 11:06 AM
  #49
celt's Avatar
Default well done...
Looked over the manual, looks to be a very, very solid chassis.
celt is offline
Old 08-07-2017, 11:10 AM
  #50
It's not bad. To me it had a little to much play in the upper arm and hing pins. And I feel it will need a front bulkhead brace as the chassis has a lot of flex being 2mm. But over all pretty nice. And extremely light as well.
chad508 is offline
Old 08-07-2017, 01:47 PM
  #51
1spunspur's Avatar
Originally Posted by liljohn1064 View Post
10R6, Please?
Good idea, are you thinking 200 or 235 mm?
1spunspur is offline
Old 08-07-2017, 03:56 PM
  #52
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I wouldn't mind both. We mostly run WGTR and I think between F6 parts and R6 parts a 200mm car would be easy to develop.
aracefan likes this.
liljohn1064 is offline
Old 08-10-2017, 10:34 AM
  #53
Just finished building my kit last night, and noticed the shock shaft is super wiggly inside the body. Did I do something wrong, or is that normal?
Old 08-10-2017, 03:40 PM
  #54
Unfortunately it's normal.
chad508 is offline
Old 08-10-2017, 05:56 PM
  #55
wow, it seems excessive to me..... ive never owned an associated pan car before this one.... i had 2 crc cars prior, their shock was super tight.
Old 08-21-2017, 09:04 AM
  #56
Default Build Notes for the RC12R6
In the UK the team are excited about the new car and looking forward to the 2017/2018 national season. I have two club runs under my belt and the car made me feel like I used to feel driving T-bar cars. Very predictable and a joy to drive.
I am probably slower than I used to be but for sure this car is faster!
I am blogging again at Mark Payne's 1/12th Scale RC Notes
I have already added a bunch of build notes for the Associated RC12R6.
Best regards
Mark Payne
Mark Payne is online now Report Post
Mark Payne is offline
Old 08-21-2017, 09:19 AM
  #57
Trader Rating: 80 (100%+)
Best regards
Mark Payne
It says the site can't be reached
MUDVAYNE is offline
Old 08-21-2017, 10:17 AM
  #58
Best regards
Mark Payne
Mark, the link has a bad URL. Can you give us a better link?
davidl is offline
Old 08-21-2017, 10:49 AM
  #59
Sorry Fixed it...
Its Here
Mark
davidl, acyrier, bounce and 1 others like this.
Old 08-21-2017, 01:42 PM
  #60
Lord_Darkhelmet's Avatar
Any idea if the new pod pivot assembly will bolt into a 12r5.2? Would be nice to get a better pivot ball and transverse battery in one upgrade.
Lord_Darkhelmet is offline
