Matt Francis Timing Jig & Break-in Stand >
Old 11-21-2002, 07:34 PM
popsracer's Avatar
Default Matt Francis Timing Jig & Break-in Stand
I just bought one of these neat looking things today and it has already started to disintegrate.
The Acrylic plates have cracks all through the holes that the stand-offs mount to. This happened after running just one motor on the stand for break-in.
Anyone else have one of these things?
popsracer is offline
Old 11-21-2002, 09:36 PM
Matt Howard's Avatar
I've had one since they first came out months ago and have had no problems at all.
Matt Howard is offline
Old 11-22-2002, 05:19 AM
Mine hasnt broken either. Did you tighten everthing by hand or did you use plyers or something to try to attach to the posts to the stand. I just installed everything by hand, I think you might have messed it up if you overtightened the stand.
Cyclonus is offline
Old 12-03-2002, 01:26 PM
popsracer's Avatar
Default OVER Tightening!!!
Well, maybe a little. I was concerned about vibration causing it to fall apart. I just put CA around all the cracked areas and it seems to be holding up fine.
Thanks,
Old 12-04-2002, 07:19 AM
When I built mine, I put an 0 ring between the posts and the plate. That way it didn't put too much pressure on it, and the vibration didn't cause the screws to back out. I had a shock dyno, and I made the mistake of putting a little locktite on the screws and no o-rings, next morning all the ears were cracked around the screws. I know you can get a new top plate for the shock dyno (Found out AFTER I threw mine out, doh!) so maybe you can get one for the break in stand as well.
Action-RC.com is offline
Old 12-04-2002, 10:15 PM
JimmyMac's Avatar
Trinity was selling them for like $13 at Cleveland... how much do these retail for? Anyhow my friends pick them up and has not had a problem with them yet. I think the over tightening of them with the acrylic will cause cracks due to vibration. Best to leave them hand tightened...
JimmyMac is offline
