Old 01-20-2006, 08:26 AM   #1
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Default Warmers and compound
Just picked up a set of Speedmind Tire warmers.. going to be racing indoors with CS-22's, so will the full 12V (55-68C) be overkill? Should I just hook up a 7.2V battery for the 36-42C? Or, run it 12V, get it hotter, and it'll give me more time between bench and race time before it cools down? Will overheating the tires do damage?
Also, I'm guessing you first put tire compound on, let it sit, wipe it off clean, then put the warmers on? Or do they both have to go on to soak fully?
On another note, found some stuff in this electronics/parts shop called "Rubber Renue".. smells rather pepperminty, might be the equivalent to the compounds we use? It's not cheap, though..
Thanks!
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 01-20-2006, 08:36 AM   #2
You could put on the traction compound first and put a sheet of paper towel over it then put on the tire warmer. Are you racing in the Magma race in FastCats? BTW, 36 degrees is good enough. Make sure that you don't remove the tire warmer until you are out to race.
trf_racer is offline   Reply With Quote
Old 01-20-2006, 08:59 AM   #3
Jam-ehz's Avatar
Yup, that's the one.. should be a good race..
VHT traction compound Grinder Nitro On-Road 16 03-20-2014 11:54 AM
FS: NIB Reedy Tire Warmers, plus some Speedmind Tire Warmers. Mustangz R/C Items: For Sale/Trade 1 03-25-2008 11:11 PM
pro compound sean Nitro On-Road 2 07-28-2004 10:54 PM
What compound?????? markallen Nitro On-Road 4 12-26-2003 10:24 PM
