Like Tree707Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 02-11-2018, 06:41 PM
  #1291
TryHard's Avatar
XRS Round 1 & a bit of RC3 ? THard.co.uk
New blog post...
disaster999, robk, JETT and 1 others like this.
TryHard is offline
Old 02-12-2018, 08:28 PM
  #1292
thisguy2849's Avatar
Originally Posted by thilo-alexander View Post
Heavier oil and heavier springs on tbe rear? Is this right or is it a typo?
thisguy2849 is offline
Old 02-12-2018, 08:57 PM
  #1293
Regional Moderator
disaster999's Avatar
Originally Posted by TryHard View Post
is the MTC1 model for the RC3 available somewhere? can it be downloaded?
Antimullet likes this.
disaster999 is offline
Old 02-12-2018, 09:14 PM
  #1294
TryHard's Avatar
I'll be sending it across to Bob later... I drew it up myself.
disaster999 and Antimullet like this.
TryHard is offline
Old 02-12-2018, 09:25 PM
  #1295
EDWARD2003's Avatar
I'm interested to see MTC1 RC3 file.
EDWARD2003 is offline
Old 02-13-2018, 05:15 AM
  #1296
CristiM's Avatar
Thank you very much!
CristiM is offline
Old 02-13-2018, 06:20 PM
  #1297
snuvet75's Avatar
Trader Rating: 16 (94%+)
Maybe because the traction is too high that the rear would not rotate with softer springs.
snuvet75 is offline
Old 02-14-2018, 01:13 AM
  #1298
The reason is the car is more stable incorner and has more rotation midcorner, as the ETS layout had a fast sweeper end of straight and some 180s.
Different shock oil to make the car easier due to high traction.
thilo-alexander is offline
Old 02-14-2018, 08:42 AM
  #1299
I see it on RC3!
RC3 Model Downloads
snuvet75 likes this.
WagwanBumba is offline
Old 02-19-2018, 02:10 AM
  #1300
Suspended
Hi guys, just wondering if anyone is having troubles with the diff orings swelling and becoming tight? And would there be a different oring to try?
xterray is offline
Old 02-21-2018, 02:47 PM
  #1301
carkillaii's Avatar
it has been real quiet in here guys , Is that a good thing or a Bad thing?
carkillaii is offline
Old 02-21-2018, 03:07 PM
  #1302
I have my club champions and the Canadian Nationals in March. I'll be running 17.5 at both and the competition will be fierce. I'm not one of the top guns so any success at all will cement this chassis as my TC of choice.
carkillaii likes this.
DavidNERODease is offline
Old 02-21-2018, 03:12 PM
  #1303
golgi's Avatar
Trader Rating: 14 (100%+)
In my experience, the car out of the box has a lot of potential but needed a little help to make it truly great (at least on gray carpet). By reading this thread and also the Facebook group, I quickly learned the minor changes that could make the car great. Now this car is working extremely well for me. My guess is that others are probably also having the same experience. And probably why there isn't as much chatter. I still check in this thread fairly often because I'm always looking for any tips on improving!
golgi is offline
Old 02-21-2018, 07:00 PM
  #1304
To further apologize for my errors I'm also posting on this thread.
The MTC1 already has little to no dog bone plunge, that's again why it drives more naturally. So, I say now to tune roll centres with the upper arms and don't change the lower arm so the dog bone plunge can be as little as it can. If you feel an imbalance then tune using roll bar and springs.
DavidNERODease likes this.
30Tooth is offline
Old 02-22-2018, 06:51 AM
  #1305
Team EAM
Trader Rating: 79 (100%+)
More alumn chassis, top decks and other parts just in!
EAMotorsports is offline
