Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 06-01-2017, 08:00 PM
  #106
Originally Posted by niznai View Post
I agree on both points.
The Kawada Sigma was absolutely identical front to back in everything before all those cars you mention (2004-ish). That meant you only had to have one suspension arm spare, the bulkheads were the same, suspension mounts likewise (shock towers different).
It also had the benefit that being a single belt you could hook the motor and its associated hardware (all mounted to the motor bulkhead) at any point along the chassis (the car came with three pre-drilled sets of holes so you could have the motor forward, mid and rear) so you could choose your weight balance.
I think our cars a bit rear-biased these days because the motor hangs out the back and the electronics are up front, whilst the battery is somewhere in the middle (lengthwise). Sure, you can usually balance it out, but then you have differences left to right depending on where you place weights (how far from the centre line). This results in different inertia moments when the car rolls and this will affect how your car turns left to right. I am not sure I can measure these differences (or if they really make a difference to your car's handling) but I am sure they do exist.
This is why I am in the process of making a single belt car with central motor and saddle pack battery in an effort to distribute the weight symmetrically. More an experiment to see if it makes any difference than anything. We'll see.
something similar to the gizmo gz1 correct ? Just without the double spur gears right ?
Ricardo_d99 is offline
Old 06-01-2017, 08:57 PM
  #107
niznai's Avatar
The motor was not central left to right and bulkheads were aluminium alloy.
The car also had the narrowest bulkheads because the belt was centralised, so the diffs were the same front to back. This also meant the driveshafts were the longest I have seen in a TC, and so were the suspension arms. Very good for suspension tuning. The arms were actually moulded with two sets of holes, so you could cut them short and make the car narrower by 6mm. CVD joints standard, but no DCJ option ever developed and very difficult to adapt because of the driveshaft length.
The bulkhead width is so small, no other diff on the market fits in between.
Here's a few pictures:
http://www.rctech.net/forum/attachme...tc-sigma-1.jpg
http://www.rctech.net/forum/attachme...mage_00002.jpg
http://www.rctech.net/forum/attachme...rms-resize.jpg
Some of those show an earlier version, the SV-10, but the design is the same, differences are in how "polished" the parts are (more slender and delicate on the Sigma).
niznai is offline
Old 06-01-2017, 11:43 PM
  #108
MGU
MGU's Avatar
Wow, the diffs look really small. How durable was it, compared with other diffs the internal gears must have been a lot smaller.
MGU is offline
Old 06-02-2017, 12:21 AM
  #109
It was a ball diff
Qatmix is offline
Old 06-02-2017, 12:54 AM
  #110
MGU
MGU's Avatar
Originally Posted by Qatmix View Post
It was a ball diff
Ok, that makes sense then.
MGU is offline
Old 06-13-2017, 10:22 PM
  #111
tbrymer's Avatar
Crickets up in here!
Marcos.J likes this.
tbrymer is offline
Old 06-14-2017, 02:10 AM
  #112
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
So glad i didn't wait for this to come out.
Marcos.J and advfuel like this.
Drift_Buggy is offline
Old 06-14-2017, 11:27 AM
  #113
gijoe64's Avatar
Trader Rating: 30 (100%+)
Guys, I understand but there is no representative from Mugen here, this is there fault. But I am willing to wait for further updates, I hope someone from Mugen will see this and start giving us updates.
gijoe64 is offline
Old 06-14-2017, 04:01 PM
  #114
advfuel's Avatar
Trader Rating: 29 (100%+)
Complete car pics now on Mugen Seiki Co Ltd facebook page.
GrandeGixxer and Ggrant like this.
advfuel is offline
Old 06-14-2017, 04:54 PM
  #115
dawgmeat's Avatar
Nice looking car
Attached Thumbnails Mugen MTC1-19059995_10155368445614054_5722431362768152702_n.jpg   Mugen MTC1-19060011_10155368445559054_5025428876521724836_n.jpg   Mugen MTC1-19060082_10155368446569054_4065528906724803711_n.jpg   Mugen MTC1-19060110_10155368445629054_3387510509622594037_n.jpg   Mugen MTC1-19105487_10155368445774054_8454598644160113144_n.jpg
disaster999 likes this.
dawgmeat is offline
Old 06-14-2017, 04:56 PM
  #116
dawgmeat's Avatar
Attached Thumbnails Mugen MTC1-19105513_10155368445974054_2377195789402797565_n.jpg   Mugen MTC1-19105859_10155368445714054_4123877583131446477_n.jpg   Mugen MTC1-19114074_10155368446484054_7932027116977765046_n.jpg   Mugen MTC1-19145734_10155368446289054_615929963665832853_n.jpg   Mugen MTC1-19145798_10155368446344054_5503846339558002975_n.jpg
dawgmeat is offline
Old 06-14-2017, 05:01 PM
  #117
dawgmeat's Avatar
Attached Thumbnails Mugen MTC1-19145842_10155368446149054_7096534861606367731_n.jpg   Mugen MTC1-19148889_10155368444799054_390889769245200862_n.jpg   Mugen MTC1-19148926_10155368446449054_1817945489184901268_n.jpg
dawgmeat is offline
Old 06-14-2017, 05:10 PM
  #118
team green's Avatar
Trader Rating: 14 (100%+)
This for sure will be my next TC. ������
Ggrant likes this.
team green is offline
Old 06-14-2017, 05:30 PM
  #119
thisguy2849's Avatar
Preorders start in a couple weeks per Mugen
tbrymer likes this.
thisguy2849 is offline
Old 06-14-2017, 05:52 PM
  #120
tbrymer's Avatar
And released end of July
tbrymer is offline
