Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 12-11-2017, 09:13 AM
  #1171
carkillaii's Avatar
Just spoke with Mugen USA , They said that there not aware of such issues with castor blocks. I was asked to send some pics tonight.
carkillaii is offline
Old 12-11-2017, 04:04 PM
  #1172
Trader Rating: 26 (100%+)
Originally Posted by Marcos.J View Post
that sucks Randy but your car looked pretty good!! See you saturday ! (check with nick he nay have a spare)
just like he will have the mtc1 for you tomorrow or is that today
no tomorrow
Marcos.J likes this.
RANDY SMOOTH is offline
Old 12-11-2017, 04:07 PM
  #1173
Super Moderator
Marcos.J's Avatar
Trader Rating: 211 (100%+)
no tomorrow
Iím sure he will have it on Tuensday
Marcos.J is offline
Old 12-11-2017, 04:08 PM
  #1174
Super Moderator
Marcos.J's Avatar
The mi5evo/mi6 mini caster blocks look like they would be a perfect fit
Marcos.J is offline
Old 12-11-2017, 04:20 PM
  #1175
i just set my radio end point and will take it from there
and get a new one. not sure when it broke but it still ran
fine. the car is great can't wait to run it Saturday
Old 12-11-2017, 05:30 PM
  #1176
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
Trying to put the new Robert Pietch setup on my car. Trying to put the stupid shims under the front inner uprights. I might not have any hair left by the time I get them in.
Antimullet likes this.
GrandeGixxer is offline
Old 12-12-2017, 05:20 AM
  #1177
Trader Rating: 65 (100%+)
I stick them on a hex wrench then drop them all down onto the aluminum, Then carefully drop the upper mount onto them with the screws in it already.
Its like that annoying kids game operation.
Or you can just ca the darn washers lol...
Antimullet is offline
Old 12-12-2017, 08:14 AM
  #1178
I’ll try that. Not having enough of the Mugen ones, I’ve got some .5 mm ones that I’m using as well. That’s not helping my cause. I gave up for the night last night after I lost one in the carpet. Today is a new day and I’ll find it and get it put back together.
Old 12-12-2017, 05:12 PM
  #1179
robk's Avatar
Trader Rating: 22 (100%+)
I found it's easier to put the rear screw in the mount with the shims, start the screw into the bulkhead, then add the front screw and swing the front screw into alignment with the shims on it. Of course, the outer ball should be off of the steering knuckle.
BTW started with the Dankel setup, which is pretty close to Pietsch 's, in USGT last weekend. I went to high diffs, 10K in the rear diff and .5mm spacer behind the front arm for caster. Reduced the droop a little as well. The car was really good, but still not as fast as the fast Awesomatix guys at my track. Moving in the right direction, though.
GrandeGixxer and Antimullet like this.
robk is offline
Old 12-14-2017, 02:31 AM
  #1180
The Teacher's Avatar
Trader Rating: 58 (100%+)
Has anyone tried the new Vigor shock tower or upper decks?
The Teacher is offline
Old 12-14-2017, 06:19 AM
  #1181
Regional Moderator
disaster999's Avatar
I just installed it on my car. They notched the back side of the tower so it keys into the bulkhead and provides JUST enough clearance so that the shock tower barely clears the screws on the bulkhead. I havent tested it on the track yet, but just flexing the tower its feels stiffer than the stock one for sure.
disaster999 is offline
Old 12-14-2017, 06:49 PM
  #1182
snuvet75's Avatar
Trader Rating: 16 (94%+)
I noticed that the stock tower is very flexible. Maybe too much compared with other brands.
snuvet75 is offline
Old 12-22-2017, 08:12 AM
  #1183
carkillaii's Avatar
Vigor RR Shock Tower & Fan Mount.
Old 12-22-2017, 08:16 AM
  #1184
What belts are those?
Old 12-22-2017, 08:21 AM
  #1185
carkillaii's Avatar
www.radtec-rc.com
GrandeGixxer likes this.
