Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 10-03-2017, 06:35 PM
  #961
Regional Moderator
disaster999's Avatar
Originally Posted by team green View Post
I thought drilling blank shock pistons was a pain lol. I'm going to need a steady hand for this.
Its not that hard really. The hardest part is get the hole started since your trying to drill into a round object. I just took a sharp body reamer to start the hole first like a center punch then used a 2mm bit to drill the hole
disaster999 is offline
Old 10-06-2017, 03:41 AM
  #962
carkillaii's Avatar
If you feel the stock bumper is too soft you can use VBC hard bumper it's a direct fit.
LOW ET and DavidNERODease like this.
carkillaii is offline
Old 10-06-2017, 03:48 PM
  #963
Trader Rating: 65 (100%+)
What is the stock spur gear pitch and tooth count?
liljohn1064 likes this.
Antimullet is offline
Old 10-06-2017, 04:00 PM
  #964
theproffesor's Avatar
Trader Rating: 63 (100%+)
Google. Search " mugen MTC1 manual" It's like it knows what you're looking for.
http://www.mugenracing.com/content/O...ls/MTC1-HP.pdf
theproffesor is offline
Old 10-06-2017, 04:03 PM
  #965
team green's Avatar
Trader Rating: 14 (100%+)
It doesn't come with a spur gear.
Antimullet likes this.
team green is offline
  #966
Trader Rating: 19 (100%+)
iTz Nicholas72 is offline
Old 10-06-2017, 05:18 PM
  #967
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Hi Aaron,
The tooth count that fits now sits in the wiki on top of each gear chart. The updated gear chart also is color coded for what fits (Nice update). This was a huge problem for me with as many helpful answers you appear to be getting. For some reason people get gear chart stuck in their head and assume that because it's in the chart the gears actually fit the car. I'm running a 21.5 with a 96 spur and 40 Pinion, 1.7 internal ratio for a 4.08 in my initial setup. If your track considers 17.5 stock, I'd probably try a 100 tooth.
liljohn1064 is offline
Old 10-06-2017, 09:24 PM
  #968
FYI: Mugen Seiki MTC1 Manual & Setup Sheets
Arn0 is offline
Old 10-07-2017, 01:31 AM
  #969
Didnít state anywhere manual or otherwise about the actual physical gear it came with. Which is why I asked professor genius.
Itís like you ASSumed you knew what you were talking about without actually looking.
Ggrant likes this.
Old 10-07-2017, 05:22 AM
  #970
30Tooth is offline
Old 10-07-2017, 07:00 AM
  #971
Originally Posted by 30Tooth View Post
Ha! Well played Sir! Reading is fundamental. I’ll take the hit for missing those two important words.
I guess I’ll start in the 100toith 64p range.
carkillaii and liljohn1064 like this.
Old 10-07-2017, 07:28 AM
  #972
Ha! Well played Sir! Reading is fundamental. Iíll take the hit for missing those two important words.
I guess Iíll start in the 100toith 64p range.
Sounds good, anything more just ask
30Tooth is offline
Old 10-07-2017, 10:44 AM
  #973
MGU
MGU's Avatar
We run around 4.5 around here so for the Mugen I actually us a 106 teeth spur gear
MGU is offline
Old 10-07-2017, 10:55 AM
  #974
Cool thanks man yea weíre down in that range as well.
Old 10-07-2017, 11:43 PM
  #975
Trader Rating: 16 (100%+)
Been info by another mugen owner at my track that the manual caster setting is not 4į its more like 2.5į. Anyone else checked the manual caster setting?
kingfish83 is offline
