Mugen MTC1
#902
Can you share your setup?
Thanks!
Thanks!
I have the car for 17.5 racing. I had a great race last week at the Activ Rc race at the Tamiya USA track. Home of the Reedy Race. The car was on pace with all of the awesomatix, xray and Tc7.1 sedans. I was the only MTC1 in the A main. We had an A,B, C, D main in 17.5. I only had two practice packs on the car before qualifying started. All racers were on spec Rush 36 premount tires. The only change from the stock asphalt setup was a set of springs. I was offered to run a different set of springs from AJ. He ran his MTC1 in mod. I ran the SMJ 2.5-2.8 front springs and Xray 2.6 rears. The car was on rails and super fast thru the S turns coming onto the straight. I loved it and cant wait to race it again.
Just for reference... In the A main were no chumps :
3 Tamiya TCS National Champions
Reedy Race Open mod champion
2 Reedy Race champions in 17.5 ( one is myself)
2 Reedy open mod A main finalists
2 13.5 Reedy a main finalists.
#903
I had a look at one of Atsushi Hara's setup sheet and the front settings for antidive caught my attention.
If I do not read this wrong, he move FF out 1° and FR IN 1° which gives him 2 degress of toe-out which I somehow doubt.
Taking a look at the rear he moves out on RR and in on RF, which would normally result in increased toe-in. Is it possible that this is a miss-entry and RF is really moved out by 0.5° and not in?
Which would then also mean something different for the front?
I am a little bit lost here.
#905
Regional Moderator
#906
#908
I built my kit per the stock instructions for asphalt. I used the stock shock oils ( 450cst) and 3000 rear diff oil. The only changes were to run the diffs in the up position and I changed the springs. I used SMJ 2.5-2.8 progressive springs up front and Xray 2.6 rear springs. I borrowed these from a fellow racer and it made a huge difference. The stock springs were not as consistent at the Tamiya USA track. I did have alot of time between heats, so I checked the rear diff fluid. It was clear but very empty. There was no real leakage, so I refilled it to the line and re-installed everything. That was a big deal as the diff now worked when it had fluid in it.
The only other tip came from my friend. I did the caster wrong. I did not realize that the picture in the manual is reversed so I had the caster flipped and the car was soo hard to drive, too responsive and the back end was loose. When i corrected it, it was much easier to drive. After that is when I checked the rear diff and it was low.
#913
Attached you will find a color coded gear chart for 48dP
#914
Thks
Dixon
#915
in the instructions, one picture shows the upper arm facing front and the next picture with the clips shows the arm facing rear. I used the set screw to determine this. The set screw should face the rear. I put 1.5mm of shims in the rear of the upper a arms. I originally had 1.5mm spacing at the front and it had way too much steering.
